Move SPL_OS_BOOT to Kconfig and cleanup existing
uses.
Move this option to Kconfig and tidy up existing uses.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
On all TI platforms the ROM defines a "downloaded image" area at or near
the start of SRAM which is followed by a reserved area. As it is at
best bad form and at worst possibly harmful in corner cases to write in
this reserved area, we stop doing that by adding in the define
NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image
area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this.
At current we define the end of scratch space at 0x228 bytes past the
start of scratch space this this gives us a lot of room to grow. As
these scratch uses are non-optional today, all targets are modified to
respect this boundary.
Tested on OMAP4 Pandaboard, OMAP3 Beagle xM
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Adam Ford <aford173@gmail.com>
Cc: Steve Sakoman <sakoman@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Thomas Weber <weber@corscience.de>
Cc: Hannes Schmelzer <oe5hpm@oevsv.at>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Sam Protsenko <semen.protsenko@linaro.org>
Cc: Samuel Egli <samuel.egli@siemens.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Cc: Ben Whitten <ben.whitten@gmail.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Mugunthan V N <mugunthanvnm@ti.com>
Cc: "B, Ravi" <ravibabu@ti.com>
Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Ash Charles <ashcharles@gmail.com>
Cc: "Kipisz, Steven" <s-kipisz2@ti.com>
Cc: Daniel Allred <d-allred@ti.com>
Tested-by: Lokesh Vutla <lokeshvutla@ti.com>
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Tested-by: Ladislav Michl <ladis@linux-mips.org>
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all
cases we are mirroring the values used by the Linux Kernel here. Also,
so long as (and in this case, it is true) we implement flushes in hunks
that are no larger than the smallest implementation (and given that we
mirror the Linux Kernel, again we are fine) it is OK to align higher.
The biggest changes here are that we always use 64 bytes for CPU_V7 even
if for example the underlying core is only 32 bytes (this mirrors
Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the
Linux Kernel) as we do not need multi-platform support (to this degree)
and only the Cavium ThunderX 88xx series has a use for such large
alignment.
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Steve Rae <steve.rae@raedomain.com>
Cc: Stefan Agner <stefan.agner@toradex.com>
Acked-by: Heiko Schocher <hs@denx.de>
Cc: Peter Griffin <peter.griffin@linaro.org>
Acked-by: Paul Kocialkowski <contact@paulk.fr>
Acked-by: "Pali Rohár" <pali.rohar@gmail.com>
Cc: Grazvydas Ignotas <notasas@gmail.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Robert Baldyga <r.baldyga@samsung.com>
Cc: David Feng <fenghua@phytium.com.cn>
Cc: Alison Wang <b18965@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com>
Cc: Mingkai Hu <mingkai.hu@nxp.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Cc: Aneesh Bansal <aneesh.bansal@freescale.com>
Cc: Saksham Jain <saksham.jain@nxp.com>
Cc: Qianyu Gong <qianyu.gong@nxp.com>
Cc: Wang Dongsheng <dongsheng.wang@nxp.com>
Cc: Alex Porosanu <alexandru.porosanu@freescale.com>
Cc: Hongbo Zhang <hongbo.zhang@nxp.com>
Cc: tang yuantian <Yuantian.Tang@freescale.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Josh Wu <josh.wu@atmel.com>
Cc: Bo Shen <voice.shen@atmel.com>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Christophe Ricard <christophe-h.ricard@st.com>
Cc: Anand Moon <linux.amoon@gmail.com>
Cc: Beniamino Galvani <b.galvani@gmail.com>
Cc: Carlo Caione <carlo@endlessm.com>
Cc: huang lin <hl@rock-chips.com>
Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Cc: Xu Ziyuan <xzy.xu@rock-chips.com>
Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com>
Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar>
Cc: Kever Yang <kever.yang@rock-chips.com>
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bernhard Nortmann <bernhard.nortmann@web.de>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Alexander Graf <agraf@suse.de>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: "Andrew F. Davis" <afd@ti.com>
Cc: Murali Karicheri <m-karicheri2@ti.com>
Cc: Carlos Hernandez <ceh@ti.com>
Cc: Gong Qianyu <Qianyu.Gong@freescale.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-by: Chin Liang See <clsee@altera.com>
The meaning of CONFIG_USB in U-Boot is different from that in Linux.
As you see in drivers/usb/Kconfig of Linux, CONFIG_USB enables the
USB host controller support, while CONFIG_USB_SUPPORT is used to
enable the whole of the USB sub-system.
When I added CONFIG_USB into Kconfig by commit 6e7e9294d321 ("usb:
add basic USB configs in Kconfig"), I planned to follow the Linux's
convention, i.e. CONFIG_USB to enable/disable the USB host support.
Then, commit 68f7c5db2d1e ("usb: Generic USB Kconfig option, that
fits both host and gadget and comments") changed the logic of the
CONFIG_USB to point to the whole of the USB sub-system. As a result,
currently we do not have an option for USB host.
This commit adds CONFIG_USB_HOST, which will be useful to compile
in the USB host support code.
CONFIG_USB_HOST is not referenced at all, but strangely some boards
define it in board headers. I removed them because USB_HOST will be
selected in Kconfig going forward.
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2
means the autoboot with no delay, with no abort check even if
CONFIG_ZERO_BOOTDELAY_CHECK is defined.
To sum up, the autoboot behaves as follows:
[1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y
autoboot with no delay, but you can abort it by key input
[2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n
autoboot with no delay, with no check for abort
[3] CONFIG_BOOTDELAY=-1
disable autoboot
[4] CONFIG_BOOTDELAY=-2
As you notice, [2] and [4] come to the same result, which means we
do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the
cases only by CONFIG_BOOTDELAY, like this:
[2] CONFIG_BOOTDELAY=-1
disable autoboot
[3] CONFIG_BOOTDELAY=-2
This commit converts the logic as follow:
--> CONFIG_BOOTDELAY=-2
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Christian Riesch <christian.riesch@omicronenergy.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Create an entry for "config USB_XHCI_DWC3" in Kconfig and
switch over to it for all boards.
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it
into CONFIG_USB_XHCI_HCD.
As commented in the help of "config USB_XHCI" entry, this has been
a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI
have been unified in favor of the former.
Note:
Some boards define CONFIG_USB_XHCI in their headers without
CONFIG_USB, which does not meet the "depends on" in Kconfig.
I added CONFIG_USB=y for those boards when converting.
Otherwise, they would fail to build.
Add support for EEPROM and EEPROM layout commands for CM-T43.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Commit 755324 (configs: Use config_distro_defaults.h in ti_armv7_common.h)
made ti_armv7_common.h include config_distro_defaults.h. This breaks the
bootdelay feature in cm_t43 because now the
- #include ti_armv7_common.h (#define CONFIG_BOOTDELAY 1)
- #undef CONFIG_BOOTDELAY
- #include config_distro_defaults.h (#define CONFIG_BOOTDELAY 2)
dance in cm_t43.h is no longer valid and in fact leads to CONFIG_BOOTDELAY
not being defined.
Adapt the config file to the new inclusion hierarchy.
Update U-Boot offset and size for raw mmc boot.
During boot, U-Boot raises the CPU frequency but the CORE and MPU regulators
are not updated. This is not a problem in cold boot since the default values
that the pmic outputs are correct, but if Linux were to switch the module to a
low power OPP, the new voltage values will be retained after a reboot and the
module will likely hang once U-Boot raises the CPU frequency back up.
Set both CORE and MPU regulators to to 1.1V on boot.
Add full support for SPI flash chips to future-proof U-Boot for cm-t43.
Move CONFIG_DM_SERIAL to cm_t43_defconfig. This forces us to update the
CONFIG_SYS_NS16550_REG_SIZE value for SPL.
spl_board_init() is necessary for boot. Remove the #undef that keeps
it out of the boot sequence.
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
Zap CONFIG_NS16550_SERIAL, as the unification of ns16550 drivers
is completed.
Unify serial_omap, and use the generic binding.
Add initial support for CM-T43, an AM437x based SoM.
This support includes: serial, MMC/eMMC, NAND, USB, ETH, I2C, GPIO, DRAM
detection.
