A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Now that CONFIG_USB_MUSB_HOST is part of Kconfig, migrate that over to
the defconfig files.
Some armv7 targets are missing a cache line size declaration.
In preparation for "arm: cache: Implement cache range check for v7"
patch, add these declarations with the appropriate value for
the target's SoC or CPU.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
The config option has been removed by one of the syncs with the Linux
mainline MTD subsystem:
ff94bc40af (mtd, ubi, ubifs: resync with Linux-3.14)
It has been left inside the config files. Currently does not look to
serve any purpose, so remove it now from all the configs.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Stefan Roese <sr@denx.de>
Cc: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
Cc: Peter Barada <peter.barada@logicpd.com>
Cc: Steve Sakoman <sakoman@gmail.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Define CONFIG_MACH_TYPE to allow non DT Linux boot.
Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
Mainline CM-T3517 U-Boot environment size differs from that one
shipped with CM-T3517 boards.
Update environment size, to avoid backward compatibility issues.
SBC-T3517 evaluation board has two Eth interfaces.
Enable network retry of another interface if the default if failed
or disconnected.
Add 'netretry=yes' in the default env. Setup relevant
timeout values in the board config file.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
USB-related options are usually prefixed with CONFIG_USB and platform-specific
adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so
this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for
consistency.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
them from include/configs.
Enable the OMAP3 specific errata code for 454179, 430973, 621766
and while at it, remove legacy non-revision checked errata logic.
Signed-off-by: Nishanth Menon <nm@ti.com>
Tested-by: Matt Porter <mporter@konsulko.com>
This is in preperation of using generic cross OMAP code.
Add support for splash screen on both DVI and SCF0403 LCD.
Reviewed-by: Tom Rini <trini@ti.com>
Add both EMAC and SMC911x support.
Add both host and mUSB support.
Currently, the selection between host USB and mUSB is done through the
config file.
CompuLab cm-t3517 is Computer on Module (CoM) based on AM3517 SoC.
Features: up to 256MB DDR2, up to 512MB NAND, USB hub, mUSB, WiFi, BT,
Analog audio codec, touch screen controller, LED.
Add basic support including:
LED, Serial console, NAND, MMC, GPIO, I2C, 256MB DRAM.
