path: root/include/configs/cm_t35.h
2014-10-27Rename some defines containing FAT in their name to be filesystem genericGuillaume GARDET
Rename some defines containing FAT in their name to be filesystem generic: MMCSD_MODE_FAT => MMCSD_MODE_FS CONFIG_SPL_FAT_LOAD_ARGS_NAME => CONFIG_SPL_FS_LOAD_ARGS_NAME CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME => CONFIG_SPL_FS_LOAD_PAYLOAD_NAME CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION => CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-09-09compulab: eeprom: add support for defining eeprom i2c busNikita Kiryanov
Create CONFIG_SYS_I2C_EEPROM_BUS #define to tell the EEPROM module what I2C bus the EEPROM is located at. Make cl_eeprom_read() switch to that bus when reading EEPROM. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Dmitry Lifshitz <lifshitz@compulab.co.il> Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Reviewed-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-25ARM: omap: clean redundant PISMO_xx macros used in OMAP3pekon gupta
PISMO_xx macros were used to define 'Platform Independent Storage MOdule' related GPMC configurations. This patch - Replaces these OMAP3 specific macros with generic CONFIG_xx macros as provided by current u-boot infrastructure. - Removes unused redundant macros, which are no longer required after merging of common platform code in following commit commit a0a37183bd75e74608bc78c8d0e2a34454f95a91 ARM: omap: merge GPMC initialization code for all platform +-----------------+-----------------------------------------------------------+ | Macro | Reason for removal | +-----------------+-----------------------------------------------------------+ | PISMO1_NOR_BASE | duplicate of CONFIG_SYS_FLASH_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_NAND_BASE| duplicate of CONFIG_SYS_NAND_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_ONEN_BASE| duplicate of CONFIG_SYS_ONENAND_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_NAND_SIZE| GPMC accesses NAND device via I/O mapped registers so | | | configuring GPMC chip-select for smallest allowable | | | segment (GPMC_SIZE_16M) is enough. | +-----------------+-----------------------------------------------------------+ | PISMO1_ONEN_SIZE| OneNAND uses a fixed GPMC chip-select address-space of | | | 128MB (GPMC_SIZE_128M) | +-----------------+-----------------------------------------------------------+ +-----------------+-----------------------------------------------------------+ | PISMO1_NOR | Unused Macros | | PISMO1_NAND | | | PISMO2_CS0 | | | PISMO2_CS1 | | | PISMO1_ONENAND | | | PISMO2_NAND_CS0 | | | PISMO2_NAND_CS1 | | | PISMO1_NOR_BASE | | | PISMO1_NAND_BASE| | | PISMO2_CS0_BASE | | +-----------------+-----------------------------------------------------------+ Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-06-10Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2014-06-06omap3: remove remnant macros GPMC_NAND_ECC_LP_x8_LAYOUT and ↵pekon gupta
GPMC_NAND_ECC_LP_x16_LAYOUT OMAP3 used GPMC_NAND_ECC_LP_x8_LAYOUT and GPMC_NAND_ECC_LP_x16_LAYOUT macros to configure GPMC controller for x7 or x8 bit device connected to its interface. Now this information is encoded in CONFIG_SYS_NAND_DEVICE_WIDTH macro, so above macros can be completely removed. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-06-01usb: hub: remove CONFIG_USB_HUB_MIN_POWER_ON_DELAYStephen Warren
Now that we wait the correct specification-mandated time at the end of usb_hub_power_on(), I suspect that CONFIG_USB_HUB_MIN_POWER_ON_DELAY has no purpose. For cm_t35.h, we already wait longer than the original MIN_POWER_ON_DELAY, so this change is safe. For gw_ventana.h, we will wait as long as the original MIN_POWER_ON_DELAY iff pgood_delay was at least 200ms. I'm not sure if this is the case or not, hence I've CC'd relevant people to test this change. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tim Harvey <tharvey@gateworks.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-03-12arm: omap: cm_t35: Fix: Re-add GPMC_NAND_ECC_LP_x8_LAYOUTStefan Roese
Patch a7e36fc9 (mtd: nand: omap: remove unused #defines from common omap_gpmc.h) removed some MTD related defines. Including GPMC_NAND_ECC_LP_x8_LAYOUT. But this define is also needed for the memory controller configuration (only the x8 defines are needed, the x16 defines are the default). Without it the NAND subsystem is not configured correctly and booting into U-Boot does not work. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Pekon Gupta <pekon@ti.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-03-04mtd: nand: omap: remove unused #defines from common omap_gpmc.hpekon gupta
OMAP NAND driver can detect Page-size and OOB-size of NAND device from ONFI params or nand_id[] table. And based on that it defines ECC layout. This patch 1) removes following board configs used for defining NAND ECC layout - GPMC_NAND_ECC_LP_x16_LAYOUT (for large page x16 NAND) - GPMC_NAND_ECC_LP_x8_LAYOUT (for large page x8 NAND) - GPMC_NAND_ECC_SP_x16_LAYOUT (for small page x16 NAND) - GPMC_NAND_ECC_SP_x8_LAYOUT (for small page x8 NAND) 2) removes unused #defines in common omap_gpmc.h depending on above configs Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-02-21arm: omap: cm_t35: Remove CONFIG_SYS_BOOTMAPSZ to fix FDT Linux bootingStefan Roese
With CONFIG_SYS_BOOTMAPSZ defined, recent Linux kernel booting results in this error: Booting using the fdt blob at 0x81f00000 Loading Kernel Image ... OK ERROR: Failed to allocate 0x1189d bytes below 0x80004000. device tree - allocation error FDT creation failed! hanging...### ERROR ### Please RESET the board ### Removing this define solves this issue. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@ti.com>
2014-01-07arm: omap: cm_t35: enable gpio bank 5 clocks explicitlyNikita Kiryanov
Following commit "arm: omap3: Enable clocks for peripherals only if they are used" (f33b9bd3984fb11e1d8566a866adc5957b1e1c9d) it is now necessary to enable clocks for GPIO banks explicitly. On cm_t35, GPIO bank 5 is necessary for scf0403 lcd support. Enable GPIO bank 5 clocks. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-12-12arm: omap: cm_t35: update config fileNikita Kiryanov
This patch makes the following updates to the cm_t35 config file: - Replace "ttyS" in default environment kernel bootargs with the new "ttyO" notation. - Remove "omapfb.debug=y" from default environment kernel bootargs. - Define a minimal power-on delay for USB hub ports so that slow-to-power-on USB sticks will have enough time to become responsive. - Add support for bootz command - ulpi_reset is not necessary and always fails with the following error message: "ULPI: ulpi_reset: failed writing reset bit" So, remove it. Cc: Tom Rini <trini@ti.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefan Roese <sr@denx.de>
2013-12-12arm: omap3: Add SPL support to cm_t35Stefan Roese
Add SPL U-Boot support to replace x-loader on the Compulab cm_t35 board. Currently only the 256MiB SDRAM board versions are supported. Tested by booting via MMC and NAND. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-12-10Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/armv7/rmobile/Makefile doc/README.scrapyard Needed manual fix: arch/arm/cpu/armv7/omap-common/Makefile board/compulab/cm_t335/u-boot.lds
2013-11-13i2c, omap24xx: convert driver to new mutlibus/mutliadapter frameworkHeiko Schocher
- add omap24xx driver to new multibus/multiadpater support - adapted all config files, which uses this driver Tested on the am335x based siemens boards rut, dxr2 and pxm2 posted here: http://patchwork.ozlabs.org/patch/263211/ Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Tom Rini <trini@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Thomas Weber <weber@corscience.de> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Nishanth Menon <nm@ti.com> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Michael Jones <michael.jones@matrix-vision.de> Cc: Raphael Assenat <raph@8d.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2013-11-12cm_t35: use scf0403 driverNikita Kiryanov
Use scf0403 driver to add scf0403x LCD support for cm-t35 and cm-t3730 boards. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-11-11cm-t35: use gpio_led driver for status ledIgor Grinberg
Switch to using the generic gpio_led driver instead of the private to cm_t35 board led implementation. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Tested-by: Nikita Kiryanov <nikita@compulab.co.il>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-01cm_t35: turn on GPIO commandsNikita Kiryanov
Turn on GPIO commands for cm-t35 and cm-t3730. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-11-01cm_t35: reduce default bootdelay to 3 secondsNikita Kiryanov
Current default bootdelay of 10 seconds is too long. Reduce default bootdelay to 3 seconds. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-08-15ARM: OMAP: Add CONFIG_OMAP_COMMONLokesh Vutla
Adding a new CONFIG_OMAP_COMMON which is included by all boards that needs to build cpu/armv7/omap-common folder. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-07-01omap: cm_t35: Fix cm_t35 for weak splash_screen_prepareRobert Winkler
Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-05-10cm-t35: update config fileIgor Grinberg
Several minor updates to the cm-t35 config file. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Tested-by: Nikita Kiryanov <nikita@compulab.co.il>
2013-03-22cm-t35: add support for loading splash image from NANDNikita Kiryanov
Add support for loading splash image from NAND Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-11cm_t35: prevent splashimage from being set to a bad valueNikita Kiryanov
Define CONFIG_SPLASHIMAGE_GUARD to prevent splashimage from being set to a value that will cause U-Boot to hang while displaying a splash screen. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-08cm-t35: add support for dvi displaysNikita Kiryanov
Add support for dvi displays with user selectable dvi presets. Cc: Wolfgang Denk <wd@denx.de> Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Cc: Anatolij Gustschin <agust@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-01-29Remove unused CONFIG_SYS_I2C_BUS[_SELECT]Michael Jones
"CONFIG_SYS_I2C_BUS" and "CONFIG_SYS_I2C_BUS_SELECT" don't appear anywhere outside of config files. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-01-08Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-12-20cm-t35: add USB host supportNikita Kiryanov
Add support for USB host ports on cm-t3530 and cm-t3730. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-12-10cm-t35: enable zero bootdelay checkNikita Kiryanov
Enable zero bootdelay check to make it possible to abort autoboot even if bootdelay == 0 Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2012-12-10OMAP3: Remove unused PHYS_SDRAM_1_SIZEThomas Weber
Remove the unused PHYS_SDRAM_1_SIZE from OMAP3 config files. Signed-off-by: Thomas Weber <thomas@tomweber.eu>
2012-10-23cm-t35: clean unused defines from configIgor Grinberg
Neither cm-t35, nor cm-t3730 is using OneNAND or flash. Remove the related defines from config file. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-10-23configs: Fix usage of mmc rescanAndrew Bradford
Fix usage of 'mmc rescan' by many configs. Proper use is 'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan the device. 'mmc rescan' itself does not take any arguments. Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01dm: Move OMAP GPIO driver to drivers/gpio/Marek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: U-Boot DM <u-boot-dm@lists.denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-07-07cm-t35: fix incorrect NAND_ECC layout selectionNikita Kiryanov
The current configuration selects an incorrect NAND ECC layout, which causes u-boot to write HW ECC data incorrectly. This patch selects the right layout. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2012-07-07cm-t35: reduce the environment sizeIgor Grinberg
Reduce the environment size (128KB => 16KB) to improve the environment operations time (e.g. reading, ecc calculation). Also, remove the unused CONFIG_SYS_ENV_SECT_SIZE. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-05-15cm-t35: add I2C multi-bus supportNikita Kiryanov
Enable I2C multi-bus support and config I2C muxes for I2C2 and I2C3. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16cm-t35: add EEPROM module and pass Linux a serial numberNikita Kiryanov
Add board specific EEPROM handling module, read the serial number from the EEPROM and pass it to Linux. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16cm-t35: cleanup the config fileNikita Kiryanov
Remove values from boolean defines, fix indentation, etc.. No functional changes. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16OMAP3: Remove unused define CONFIG_OMAP3_*_DDRThomas Weber
This patch removes the unused definitions: CONFIG_OMAP3_MICRON_DDR CONFIG_OMAP3_NUMONYX_DDR CONFIG_OMAP3_INFINEON_DDR Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06ARM: OMAP: Remove STACKSIZE for IRQ and FIQ if unusedThomas Weber
This patch removes the definition of stack sizes for irq and fiq if the CONFIG_USE_IRQ is undefined before. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06ARM: OMAP3: Remove unused define SDRC_R_C_BThomas Weber
This patch removes the unused definition of SDRC_R_C_B from the config files. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it> Acked-by: Tom Rini <trini@ti.com>
2011-12-06ARM: OMAP3: Remove unused define CONFIG_OMAP3430Thomas Weber
This patch removes the CONFIG_OMAP3430, because it is unused. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
