path: root/include/configs/cm_t35.h
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15Kconfig: OMAP: USB: Migrate CONFIG_USB_EHCI_OMAP to KconfigTom Rini
Follow the exiting logic for the i.MX options when migrating this option. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-05-15omap3: Migrate CONFIG_OMAP3_GPIO_X to KconfigTom Rini
The symbols CONFIG_OMAP3_GPIO_X control if we enable the clocks for a given GPIO bank in U-Boot. select the required banks for each target. In some cases we need to also migrate from CONFIG_USB_EHCI (deprecated, in include/configs/) to CONFIG_USB_EHCI_HCD as we only require the GPIO bank to be enabled if USB is also enabled. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15gpio: Move OMAP_GPIO to KconfigTom Rini
This driver is used often enough such that we want to have this enabled by default on any ARCH_OMAP2PLUS board, and this only compiles on ARCH_OMAP2PLUS due to required defines, so mark that as the depends. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15TI: Drop 'CONFIG_OMAP'Tom Rini
In the two cases in the code where we use CONFIG_OMAP as a useful test currently we can make use of CONFIG_ARCH_OMAP2PLUS instead. With that changed we can drop all defines of CONFIG_OMAP. While in here, CONFIG_OMAP3430 is only defined and then never used, so drop. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-09power: twl4030: Remove CONFIG_TWL4030_POWER from include/configsAdam Ford
With the addition of Kconfig now having CONFIG_TWL4030_POWER and with that being the default when OMAP34XX is selected, this is no longer needed in include/configs and can be removed from the whitelist. This has only been tested on logic PD DM3730 using ti_omap3_common.h Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-09ARM: Migrate errata to KconfigTom Rini
This moves all of the current ARM errata from various header files and in to Kconfig. This allows for a minor amount of cleanup as we had some instances where both a general common header file was enabling errata as well as the board config. We now just select these once at the higher level in Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-21status_led: Kconfig migrationUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files. TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-11-21TI: Remove CONFIG_OMAP_COMMON in favor of CONFIG_ARCH_OMAP2Tom Rini
With the move to arch/arm/mach-omap2 there are now very few uses of CONFIG_OMAP_COMMON and further they can all be replaced with CONFIG_ARCH_OMAP2, so do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-21arm: Introduce arch/arm/mach-omap2 for OMAP2 derivative platformsTom Rini
This moves what was in arch/arm/cpu/armv7/omap-common in to arch/arm/mach-omap2 and moves arch/arm/cpu/armv7/{am33xx,omap3,omap4,omap5} in to arch/arm/mach-omap2 as subdirectories. All refernces to the former locations are updated to the current locations. For the logic to decide what our outputs are, consolidate the tests into a single config.mk rather than including 4. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-18spl: Remove CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORSSemen Protsenko
This option isn't used for anything, so get rid of it. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2016-09-06TI: Rework SRAM definitions and maximumsTom Rini
On all TI platforms the ROM defines a "downloaded image" area at or near the start of SRAM which is followed by a reserved area. As it is at best bad form and at worst possibly harmful in corner cases to write in this reserved area, we stop doing that by adding in the define NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this. At current we define the end of scratch space at 0x228 bytes past the start of scratch space this this gives us a lot of room to grow. As these scratch uses are non-optional today, all targets are modified to respect this boundary. Tested on OMAP4 Pandaboard, OMAP3 Beagle xM Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Paul Kocialkowski <contact@paulk.fr> Cc: Enric Balletbo i Serra <eballetbo@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Weber <weber@corscience.de> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Heiko Schocher <hs@denx.de> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: "B, Ravi" <ravibabu@ti.com> Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: "Kipisz, Steven" <s-kipisz2@ti.com> Cc: Daniel Allred <d-allred@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Ladislav Michl <ladis@linux-mips.org>
2016-07-01autoboot: remove CONFIG_ZERO_BOOTDELAY_CHECKMasahiro Yamada
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2 means the autoboot with no delay, with no abort check even if CONFIG_ZERO_BOOTDELAY_CHECK is defined. To sum up, the autoboot behaves as follows: [1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n autoboot with no delay, with no check for abort [3] CONFIG_BOOTDELAY=-1 disable autoboot [4] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort As you notice, [2] and [4] come to the same result, which means we do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the cases only by CONFIG_BOOTDELAY, like this: [1] CONFIG_BOOTDELAY=0 autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=-1 disable autoboot [3] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort This commit converts the logic as follow: CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n --> CONFIG_BOOTDELAY=-2 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Christian Riesch <christian.riesch@omicronenergy.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2016-05-20arm: cm-t35: add support for eeprom layout comandsNikita Kiryanov
Add support for EEPROM and EEPROM layout commands for CM-T35. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-31armv7: add cacheline sizes where missingAlbert ARIBAUD
Some armv7 targets are missing a cache line size declaration. In preparation for "arm: cache: Implement cache range check for v7" patch, add these declarations with the appropriate value for the target's SoC or CPU. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reviewed-by: Tom Rini <trini@konsulko.com>
