path: root/include/configs/cm_t35.h
2012-10-23cm-t35: clean unused defines from configIgor Grinberg
Neither cm-t35, nor cm-t3730 is using OneNAND or flash. Remove the related defines from config file. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-10-23configs: Fix usage of mmc rescanAndrew Bradford
Fix usage of 'mmc rescan' by many configs. Proper use is 'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan the device. 'mmc rescan' itself does not take any arguments. Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01dm: Move OMAP GPIO driver to drivers/gpio/Marek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: U-Boot DM <u-boot-dm@lists.denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-07-07cm-t35: fix incorrect NAND_ECC layout selectionNikita Kiryanov
The current configuration selects an incorrect NAND ECC layout, which causes u-boot to write HW ECC data incorrectly. This patch selects the right layout. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2012-07-07cm-t35: reduce the environment sizeIgor Grinberg
Reduce the environment size (128KB => 16KB) to improve the environment operations time (e.g. reading, ecc calculation). Also, remove the unused CONFIG_SYS_ENV_SECT_SIZE. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-05-15cm-t35: add I2C multi-bus supportNikita Kiryanov
Enable I2C multi-bus support and config I2C muxes for I2C2 and I2C3. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16cm-t35: add EEPROM module and pass Linux a serial numberNikita Kiryanov
Add board specific EEPROM handling module, read the serial number from the EEPROM and pass it to Linux. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16cm-t35: cleanup the config fileNikita Kiryanov
Remove values from boolean defines, fix indentation, etc.. No functional changes. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16OMAP3: Remove unused define CONFIG_OMAP3_*_DDRThomas Weber
This patch removes the unused definitions: CONFIG_OMAP3_MICRON_DDR CONFIG_OMAP3_NUMONYX_DDR CONFIG_OMAP3_INFINEON_DDR Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06ARM: OMAP: Remove STACKSIZE for IRQ and FIQ if unusedThomas Weber
This patch removes the definition of stack sizes for irq and fiq if the CONFIG_USE_IRQ is undefined before. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06ARM: OMAP3: Remove unused define SDRC_R_C_BThomas Weber
This patch removes the unused definition of SDRC_R_C_B from the config files. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it> Acked-by: Tom Rini <trini@ti.com>
2011-12-06ARM: OMAP3: Remove unused define CONFIG_OMAP3430Thomas Weber
This patch removes the CONFIG_OMAP3430, because it is unused. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-09-04OMAP3: CM-T35: Use generic MMC driverTom Rini
Switch from the legacy omap3 mmc driver to the new generic omap hsmmc driver. This patch is based on the work done for Beagle, etc. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-04Removed unused define, CONFIG_ARMV7.Christopher Harvey
Signed-off-by: Christopher Harvey <charvey@matrox.com>
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-04-27ARMV7: OMAP3: Cleanup extern variables in mem.cLuca Ceresoli
Removed boot_flash_* extern variables. boot_flash_type was totally unused. The other ones were actually constants, so they have been replaced with #defines in the board config files. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27OMAP3: CM-T35: Add support for CM-T3730Igor Grinberg
CM-T3730 is exactly the same board as CM-T35, but it has TI DM3730 SoC onboard and therefore some changes have to take place Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27OMAP3: CM-T35: enable the green LEDIgor Grinberg
2011-04-27OMAP3: CM-T35: fix mmcIgor Grinberg
Use CONFIG_OMAP3_MMC in cm-t35 configuration file. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27OMAP3: CM-T35: update board files header informationIgor Grinberg
2011-04-27OMAP3: CM-T35: update configIgor Grinberg
update config for OMAP3 CM-T35 Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-02-02OMAP3: add CM-T35 boardMike Rapoport
This patch adds support for CM-T35 board Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
