CONFIG_SYS_STDIO_DEREGISTER
This option should never be enabled in SPL, so use
CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option.
[trini: Re-sync]
CONFIG_VIDEO_SW_CURSOR
[trini: Re-convert, find all the cases where this is off]
CONFIG_VGA_AS_SINGLE_DEVICE
Once we migrate to driver model for video, we should be able to drop this
option.
CONFIG_CFB_CONSOLE
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing
uses.
Move this option to Kconfig and tidy up existing uses.
The cm-fx6 module has an on-board spi flash chip. Enable mtd support
and the mtdparts command. Also define a default partitioning, add
it to the default environment, and enable support to overwrite the
partitioning defined in a device tree by it. Finally, probe for the
chip on preboot to register the flash chip and, thus, establish the
connection between the mtd environment settings and the actual device.
These changes move the effective default partitioning from the device
tree shipped with the vendor kernels to U-Boot which becomes the single
point of definition for the partitioning for all device tree based
kernels (in particular, for the upstream Linux kernel which does not
have a default partitioning defined in its device tree).
Signed-off-by: Christopher Spinrath <christopher.spinrath@rwth-aachen.de>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Currently, entire script segments have to be changed in the default
environment to change the kernel image location or to append kernel
cmdline parameters. In the later case this has to be changed for
every possible boot device.
Introduce new variables for kernel image locations and boot device
independent kernel parameters to make it easier to change these
settings.
Reviewed-by: Igor Grinberg <grinberg@compulab.co.il>
Reviewed-by: Nikita Kiryanov <nikita@compulab.co.il>
Add support for EEPROM and EEPROM layout commands for CM-FX6.
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Use spl alternate boot device feature to define fallback to
the main boot device as it is defined by hardware.
The driver assumed that I2C1 and I2C2 were always enabled,
and if they were not, then an asynchronous abort was (silently)
raised, to be caught much later on in the Linux kernel.
Fix this by making I2C1 and I2C2 optional just like I2C3 and I2C4
are.
To make the change binary-invariant, declare I2C1 and I2C2 in
every include/configs/ file which defines CONFIG_SYS_I2C_MXC.
Also, while updating README about CONFIG_SYS_I2C_MXC_I2C1 and
CONFIG_SYS_I2C_MXC_I2C2, add missing descriptions for I2C4 speed
(CONFIG_SYS_MXC_I2C4_SPEED) and slave (CONFIG_SYS_MXC_I2C4_SLAVE)
config options.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
Print board revision for cm-fx6.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
[trini: Add spring, sniper, smartweb to conversion]
Add kconfig options for various SPI flashes and use them in cm-fx6 defconfig.
Cc: Jagan Teki <jteki@openedev.com>
Add Kconfig options for USB keyboard and use them for cm-fx6.
Add USB_EHCI_MX6 option to menuconfig and use it when migrating cm-fx6 usb
config to defconfig.
Move CONFIG_CMD_* options that can be selected in menuconfig to cm-fx6
defconfig.
Implement a cm-fx6 specific board_video_skip() to provide the option to not
initialize the display.
The new function does not init display if the environment variable "panel" is
not defined, or if it is set to an unsupported value.
Collateral changes:
- Don't use the global displays array (it's CONFIG_IMX_VIDEO_SKIP specific).
- Don't use detect_hdmi(), since env controlled init makes it unnecessary.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
Move all standard mx6 MMC configs to mx6_common.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Reviewed-by: Tom Rini <trini at konsulko.com>
Move generic miscellaneous options that are standard across most, if not all,
mx6 boards to central mx6_common define to ensure consistent features.
Define common LOADADDR and BOOTDELAY to ensure a consistent experience
across mx6 boards
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common
Define the standard ATAG consfigs in mx6_common.
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO
and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h,
config_cmd_default.h includes are used fairly universally across imx6 boards
so include them in mx6_common.h by default.
We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we
don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere.
Some SoCs have more than two I2C busses. Instead of adding ifdef
to the driver, macros are put into board header file where
CONFIG_SYS_I2C_MXC is defined.
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Heiko Schocher <hs@denx.de>
Move this option to Kconfig and update all boards.
Remove driver model CONFIGs from the board config headers and use Kconfig
instead.
Move board/compulab/common/splash.c code to
common/splash_source.c to make it available for everybody. This move
renames cl_splash_screen_prepare() to splash_source_load(), and
the compilation of this code is conditional on CONFIG_SPLASH_SOURCE.
splash_source features:
* Provide a standardized way for declaring board specific splash screen
locations
* Provide existing routines for auto loading the splash image from the
locations as declared by the board
* Introduce the "splashsource" environment variable, which makes it
possible to select the splash image source.
cm-t35 and cm-fx6 are updated to use the modified version.
Cc: Tom Rini <trini@ti.com>
Reviewed-by: Tom Rini <trini@ti.com>
Add support for splash screen.
The splash screen is loaded from the SPI flash and is displayed on the
HDMI display.
[grinberg@compulab.co.il: minor code and commit message updates]
Add support for usb keyboard for cm_fx6.
Add compulab logo and display it on boot.
Add support for hdmi console.
Increase size of malloc area to make room for framebuffer
and other such big allocations.
Expand boot sequence to the following order:
1) mmc boot: mmc boot script, then mmc bootm, then mmc bootz.
2) usb boot: usb boot script.
3) sata boot: sata boot script, sata bootm, sata bootz.
4) nand boot: nand bootm, then nand bootz.
CONFIG_SYS_HZ is always defined as 1000 in config_fallbacks.h
(but some boards still have redundant definitions).
This commit moves the definition and the document in README to
Kconfig. Since lib/Kconfig can assure that CONFIG_SYS_HZ is 1000,
the sanity check in lib/time.c should be removed.
Now that serial and GPIO are available for iMX.6, move cm_fx6 over as an
example.
Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
We should not hardcode CONFIG_NETMASK in the config file.
Add support for SATA.
Use Compulab eeprom module to obtain revision number, serial number, and
mac address from the EEPROM.
Add support for all 3 I2C busses on Compulab CM-FX6 CoM.
Add USB and USB OTG host support for Compulab CM-FX6 CoM.
