path: root/include/configs/cm_fx6.h
2016-07-19ARM: configs: cm_fx6: add mtd supportChristopher Spinrath
The cm-fx6 module has an on-board spi flash chip. Enable mtd support and the mtdparts command. Also define a default partitioning, add it to the default environment, and enable support to overwrite the partitioning defined in a device tree by it. Finally, probe for the chip on preboot to register the flash chip and, thus, establish the connection between the mtd environment settings and the actual device. These changes move the effective default partitioning from the device tree shipped with the vendor kernels to U-Boot which becomes the single point of definition for the partitioning for all device tree based kernels (in particular, for the upstream Linux kernel which does not have a default partitioning defined in its device tree). Signed-off-by: Christopher Spinrath <christopher.spinrath@rwth-aachen.de> Reviewed-by: Stefano Babic <sbabic@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2016-07-19ARM: configs: cm_fx6: improve default environmentChristopher Spinrath
Currently, entire script segments have to be changed in the default environment to change the kernel image location or to append kernel cmdline parameters. In the later case this has to be changed for every possible boot device. Introduce new variables for kernel image locations and boot device independent kernel parameters to make it easier to change these settings. Signed-off-by: Christopher Spinrath <christopher.spinrath@rwth-aachen.de> Reviewed-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Nikita Kiryanov <nikita@compulab.co.il>
2016-05-20arm: cm-fx6: add support for eeprom layout comandsNikita Kiryanov
Add support for EEPROM and EEPROM layout commands for CM-FX6. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-11-18arm: mx6: cm-fx6: define fallback boot devices for splNikita Kiryanov
Use spl alternate boot device feature to define fallback to the main boot device as it is defined by hardware. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2015-10-02I2C: mxc_i2c: make I2C1 and I2C2 optionalAlbert ARIBAUD \\(3ADEV\\)
The driver assumed that I2C1 and I2C2 were always enabled, and if they were not, then an asynchronous abort was (silently) raised, to be caught much later on in the Linux kernel. Fix this by making I2C1 and I2C2 optional just like I2C3 and I2C4 are. To make the change binary-invariant, declare I2C1 and I2C2 in every include/configs/ file which defines CONFIG_SYS_I2C_MXC. Also, while updating README about CONFIG_SYS_I2C_MXC_I2C1 and CONFIG_SYS_I2C_MXC_I2C2, add missing descriptions for I2C4 speed (CONFIG_SYS_MXC_I2C4_SPEED) and slave (CONFIG_SYS_MXC_I2C4_SLAVE) config options. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-09-02arm: mx6: cm-fx6: print PCB revisionNikita Kiryanov
Print board revision for cm-fx6. Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-08-02sf: kconfig: add kconfig options for spi flashesNikita Kiryanov
Add kconfig options for various SPI flashes and use them in cm-fx6 defconfig. Cc: Jagan Teki <jteki@openedev.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-08-02usb: kconfig: usb keyboard kconfigNikita Kiryanov
Add Kconfig options for USB keyboard and use them for cm-fx6. Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-08-02arm: mx6: usb: kconfig: add USB_EHCI_MX6 kconfig optionNikita Kiryanov
Add USB_EHCI_MX6 option to menuconfig and use it when migrating cm-fx6 usb config to defconfig. Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-08-02arm: mx6: cm-fx6: move CMD configs to defconfigNikita Kiryanov
Move CONFIG_CMD_* options that can be selected in menuconfig to cm-fx6 defconfig. Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-08-02arm: mx6: cm-fx6: make it possible to not init displayNikita Kiryanov
Implement a cm-fx6 specific board_video_skip() to provide the option to not initialize the display. The new function does not init display if the environment variable "panel" is not defined, or if it is set to an unsupported value. Collateral changes: - Don't use the global displays array (it's CONFIG_IMX_VIDEO_SKIP specific). - Don't use detect_hdmi(), since env controlled init makes it unnecessary. Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2015-05-26imx6: generic MMC config options to mx6_commonPeter Robinson
Move all standard mx6 MMC configs to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move generic miscellaneous and overwrite optionsPeter Robinson
Move generic miscellaneous options that are standard across most, if not all, mx6 boards to central mx6_common define to ensure consistent features. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: centralise common boot options in mx6_common.hPeter Robinson
Define common LOADADDR and BOOTDELAY to ensure a consistent experience across mx6 boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move MXC_GPIO define to mx6_common.hPeter Robinson
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move standard ATAG configs to mx6_common.hPeter Robinson
Define the standard ATAG consfigs in mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move generic imx6 options to mx6_common.hPeter Robinson
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move all standard includes to mx6_common.hPeter Robinson
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h, config_cmd_default.h includes are used fairly universally across imx6 boards so include them in mx6_common.h by default. We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-04-23driver/i2c/mxc: Enable I2C bus 3 and 4York Sun
Some SoCs have more than two I2C busses. Instead of adding ifdef to the driver, macros are put into board header file where CONFIG_SYS_I2C_MXC is defined. Signed-off-by: York Sun <yorksun@freescale.com> CC: Heiko Schocher <hs@denx.de>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: mx6: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29common: convert compulab splash load code to common codeNikita Kiryanov
Move board/compulab/common/splash.c code to common/splash_source.c to make it available for everybody. This move renames cl_splash_screen_prepare() to splash_source_load(), and the compilation of this code is conditional on CONFIG_SPLASH_SOURCE. splash_source features: * Provide a standardized way for declaring board specific splash screen locations * Provide existing routines for auto loading the splash image from the locations as declared by the board * Introduce the "splashsource" environment variable, which makes it possible to select the splash image source. cm-t35 and cm-fx6 are updated to use the modified version. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-01-29arm: mx6: cm-fx6: add splash screen supportNikita Kiryanov
Add support for splash screen. The splash screen is loaded from the SPI flash and is displayed on the HDMI display. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> [grinberg@compulab.co.il: minor code and commit message updates] Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il>
2015-01-29arm: mx6: cm-fx6: add support for usb keyboardNikita Kiryanov
Add support for usb keyboard for cm_fx6. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-01-29arm: mx6: cm-fx6: display compulab logoNikita Kiryanov
Add compulab logo and display it on boot. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-01-29arm: mx6: cm-fx6: add hdmi console supportNikita Kiryanov
Add support for hdmi console. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-01-29arm: mx6: cm-fx6: increase size of malloc areaNikita Kiryanov
Increase size of malloc area to make room for framebuffer and other such big allocations. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il>
2015-01-29arm: mx6: cm-fx6: expand boot sequenceNikita Kiryanov
Expand boot sequence to the following order: 1) mmc boot: mmc boot script, then mmc bootm, then mmc bootz. 2) usb boot: usb boot script. 3) sata boot: sata boot script, sata bootm, sata bootz. 4) nand boot: nand bootm, then nand bootz. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-10-23kconfig: move CONFIG_SYS_HZ to lib/KconfigMasahiro Yamada
CONFIG_SYS_HZ is always defined as 1000 in config_fallbacks.h (but some boards still have redundant definitions). This commit moves the definition and the document in README to Kconfig. Since lib/Kconfig can assure that CONFIG_SYS_HZ is 1000, the sanity check in lib/time.c should be removed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Marek Vasut <marex@denx.de>
2014-10-22dm: imx: Move cm_fx6 to use driver model for serial and GPIOSimon Glass
Now that serial and GPIO are available for iMX.6, move cm_fx6 over as an example. Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-22cm_fx6: Remove CONFIG_NETMASKFabio Estevam
We should not hardcode CONFIG_NETMASK in the config file. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-09arm: mx6: cm_fx6: add sata supportNikita Kiryanov
Add support for SATA. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-09arm: mx6: cm_fx6: use eepromNikita Kiryanov
Use Compulab eeprom module to obtain revision number, serial number, and mac address from the EEPROM. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-09arm: mx6: cm_fx6: add i2c supportNikita Kiryanov
Add support for all 3 I2C busses on Compulab CM-FX6 CoM. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-09arm: mx6: cm_fx6: add usb supportNikita Kiryanov
Add USB and USB OTG host support for Compulab CM-FX6 CoM. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-09arm: mx6: cm_fx6: add ethernet supportNikita Kiryanov
Add ethernet support for Compulab CM-FX6 CoM Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-09arm: mx6: cm_fx6: add nand supportNikita Kiryanov
Add NAND support for Compulab CM-FX6 CoM. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2014-09-09arm: mx6: add support for Compulab cm-fx6 CoMNikita Kiryanov
Add initial support for Compulab CM-FX6 CoM. Support includes MMC, SPI flash, and SPL with dynamic DRAM detection. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
