path: root/include/configs/cm41xx.h
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2007-07-10include/configs/[a-e]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various c* named board config files.Jon Loeliger
2005-05-23* Extend burst mode RAM test program to take a loop countwdenk
(0 = infinite) * Use CONFIG_DRIVER_KS8695ETH to enable KS8695 ethernet driver on those boards that use it.
2005-05-19Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the OpenGear CM4008 board
