path: root/include/configs/cm-bf537u.h
2010-11-19Blackfin: tweak objects specified before embedded environmentMike Frysinger
The partial linking patch changes how objects are specified to the linker and breaks boards with an embedded environment. So we need to tweak the list of objects we specify via the linker script that go in the gap before the embedded env to work with this new behavior. This fixes linker errors for all the boards in question. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: unify default I2C settings for ADI boardsMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2010-04-13blackfin: Move cpu/blackfin/* to arch/blackfin/cpu/*Peter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-01-17Blackfin: update tiny board settings (voltage/default env)Harald Krapfenbauer
The tinyboards like to run at a little lower voltage than the default, and they prefer to boot over the network. For the latter, extend the common code a little to make this easier. Also fix the cm-bf527 env sector size while we're in here to reflect the flash that is actually in use. Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: tweak embedded LDR env config optionMike Frysinger
Use the common config option for extracting the environment for embedding into LDR files and clarify the LDR-specific option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-02Blackfin: cm-bf537u: new board portHarald Krapfenbauer
The CM-BF537U is similar to the CM-BF537E module, but enough to need its own board port. Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
