path: root/include/configs/cm-bf527.h
2014-05-12blackfin: replace bfin_gen_rand_mac() with eth_random_addr()Masahiro Yamada
bfin_gen_rand_mac() uses __DATE__ as the seed for random ethernet address. This makes the build non-deterministic. In the first place, it should not be implemented as a Bfin-specific function. Use eth_random_addr() instead. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.zhang@analog.com>
2014-03-07kbuild, blackfin: Add CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEEDMasahiro Yamada
Many (but not all) of Blackfin boards give -O2 option to compile under lib/ directory. That means lib/ should be speed-optimized, whereas other parts should be size-optimized. We want to keep the same behavior, but do not want to parse board/*/config.mk again and again. We've got no choice but to invent a new method. CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED, if it is enabled, gives -O2 flag only for building under lib/ directory. Dirty codes which I had marked as "FIX ME" in board/${BOARD}/config.mk have been deleted. Instead, CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED has been defined in include/configs/${BOARD}.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.zhang@analog.com>
2012-01-26NAND: remove NAND_MAX_CHIPS definitionsVladimir Zapolskiy
This change follows the change by Wolfgang Grandegger (commit 6c869637fef), which allows to remove useless NAND_MAX_CHIPS definitions in board config files. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: unify default I2C settings for ADI boardsMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2010-01-17Blackfin: update tiny board settings (voltage/default env)Harald Krapfenbauer
The tinyboards like to run at a little lower voltage than the default, and they prefer to boot over the network. For the latter, extend the common code a little to make this easier. Also fix the cm-bf527 env sector size while we're in here to reflect the flash that is actually in use. Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: tweak embedded LDR env config optionMike Frysinger
Use the common config option for extracting the environment for embedding into LDR files and clarify the LDR-specific option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-23Blackfin: cm-bf527/cm-bf537: increase flash sectorsHarald Krapfenbauer
Newer revisions of these boards have slightly larger flashes, so increase the configured number of sectors so that U-Boot works on all revisions. Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: convert specific pre/post config headers to common methodMike Frysinger
The Blackfin port was using asm/blackfin-config-{pre,post}.h to setup common Blackfin board defines. The common method now is to use config.h, so convert blackfin-config-post.h to that. Rename the still Blackfin specific blackfin-config-pre.h to config-pre.h so the naming conventions at least line up. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: cm-bf527: new board portMike Frysinger
