We really don't want boards defining fixed MAC addresses in their config
so we just remove the option to set it in a fixed way. If you must have
a MAC address that was not provisioned, then use the random MAC address
functionality.
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com>
If this option is enabled, the objects under lib/ directory
are compiled with speed optimization, not size optimization.
(Currently, only used by some Blackfin boards.)
bfin_gen_rand_mac() uses __DATE__ as the seed for random ethernet
address. This makes the build non-deterministic.
In the first place, it should not be implemented as a Bfin-specific
function. Use eth_random_addr() instead.
Cc: Sonic Zhang <sonic.zhang@analog.com>
Many (but not all) of Blackfin boards give -O2 option
to compile under lib/ directory.
That means lib/ should be speed-optimized,
whereas other parts should be size-optimized.
We want to keep the same behavior,
but do not want to parse board/*/config.mk again and again.
We've got no choice but to invent a new method.
CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED, if it is enabled,
gives -O2 flag only for building under lib/ directory.
Dirty codes which I had marked as "FIX ME"
in board/${BOARD}/config.mk have been deleted.
Instead, CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED has been
defined in include/configs/${BOARD}.h.
This change follows the change by Wolfgang Grandegger (commit 6c869637fef),
which allows to remove useless NAND_MAX_CHIPS definitions in board config
files.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Scott Wood <scottwood@freescale.com>
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code.
The CONFIG_BFIN_CPU option is largely used in the build system, so move
it out of the board config.h and into the board config.mk. It'd be nice
to keep everything in the config.h, but the patch to extract that value
early was rejected.
Acked-by: Heiko Schocher <hs@denx.de>
The tinyboards like to run at a little lower voltage than the default, and
they prefer to boot over the network. For the latter, extend the common
code a little to make this easier.
Also fix the cm-bf527 env sector size while we're in here to reflect the
flash that is actually in use.
Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at>
Use the common config option for extracting the environment for embedding
into LDR files and clarify the LDR-specific option.
Newer revisions of these boards have slightly larger flashes, so increase
the configured number of sectors so that U-Boot works on all revisions.
The Blackfin port was using asm/blackfin-config-{pre,post}.h to setup
common Blackfin board defines. The common method now is to use config.h,
so convert blackfin-config-post.h to that. Rename the still Blackfin
specific blackfin-config-pre.h to config-pre.h so the naming conventions
at least line up.
