path: root/include/configs/cl-som-am57x.h
2017-07-28configs: Remove CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS in all boardsBin Meng
Now that xHCD does not use CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS, remove it in all boards' config files. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-06-05arm: am57xx: cl-som-am57x: adjust default env to the installation systemUri Mashiach
The SD card automatic installation system depends on the default environment of the previous U-Boot. Add the missing environment variables. Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-05arm: am57xx: cl-som-am57x: support for FS bootUri Mashiach
Supported boot devices are raw QSPI and raw SD card. Add support for a FAT16/32 file system for SD card. The SOC's boot ROM only supports FAT file system. Therefore remove the SPL support for the EXT file system. Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-08arm: am57xx: cl-som-am57x: fix USB scanUri Mashiach
USB bus scan attempt: ----------------------------------cut---------------------------------- => usb start starting USB... USB0: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... data abort pc : [<fff6240e>] lr : [<fff623b3>] reloc pc : [<8081b40e>] lr : [<8081b3b3>] sp : fdf42930 ip : fdf42960 fp : 00000000 r10: 00000001 r9 : fdf42ef0 r8 : 48890020 r7 : 00000002 r6 : fffa5840 r5 : fff8b140 r4 : fdf429c0 r3 : 00000000 r2 : 00000004 r1 : 00000000 r0 : 00000000 Flags: nZcv IRQs off FIQs off Mode SVC_32 Resetting CPU ... resetting ... ----------------------------------cut---------------------------------- Fix by enabling USB configuration in the SPL. Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Igor Grinberg <grinberg@compulab.co.il>
2017-05-08arm: dra7xx: move CONFIG_DRA7XX to KconfigUri Mashiach
The symbol CONFIG_DRA7XX is needed for Kconfig conditions. Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-24arm: am57xx: cl-som-am57x: fix EthernetUri Mashiach
The module is continuously rebooting with the following message: Net: data abort pc : [<fff77f42>] lr : [<fff6e32b>] reloc pc : [<80816f42>] lr : [<8080d32b>] sp : fdf5ce48 ip : fdf5d79c fp : 00000017 r10: 8083cd58 r9 : fdf5cef0 r8 : fdf5d5d0 r7 : 48485000 r6 : 400000ff r5 : fdf5d6e0 r4 : fdf5d618 r3 : fdf5d5b4 r2 : fdf5d5d0 r1 : 643a3631 r0 : fdf5d6e0 Flags: nzCv IRQs off FIQs off Mode SVC_32 Resetting CPU ... Modifications: * Enable Ethernet configuration in the SPL. * Update PINMUX of PHY enable GPIO. Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-21status_led: Kconfig migrationUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files. TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2017-01-02arm: am57xx: cl-som-am57x: update default envUri Mashiach
Modify U-Boot default env settings. Boot sequence: 1. SD card boot script 2. SD card boot no script 3. SATA boot script 4. SATA boot no script 5. eMMC boot script 6. eMMC boot no script Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-02arm: am57xx: cl-som-am57x: add ETH supportDmitry Lifshitz
Add MAC support. Use PHY, connected to RGMII1 as a default Eth adapter, by appropriate setting of 'cpsw_data.active_slave'. 'cpsw_phy' env variable can override this setting. Set the MAC addresses in the U-Boot environment. The addresses are retrieved from the on-board EEPROM or from the SOC's MAC fuses. Set the following PHYs RGMII clock delays: - Enable RX delay - Disable TX delay Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> [uri.mashiach@compulab.co.il: add RGMII clock delays] Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-02arm: am57xx: cl-som-am57x: fetch board rev from EEPROMDmitry Lifshitz
Add PCB revision message. Implement board revision get_board_rev API. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Commit description update. Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-02arm: am57xx: cl-som-am57x: add initial board supportDmitry Lifshitz
Features supported : * Serial console * SPI Flash * MMC/SD Card * eMMC storage * SATA * PCA9555 - GPIO expander over I2C5 bus * USB Use spl alternate boot device feature to define fallback to the main boot device as it is defined by hardware. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> [uri.mashiach@compulab.co.il: Adjust to v2016.11] Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
