path: root/include/configs/chromebox_panther.h
2016-03-22net: Move CONFIG_RTL8169 to KconfigBin Meng
Introduce CONFIG_RTL8169 in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Stephen Warren <swaren@nvidia.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-05x86: chromebox_panther: Drop the cache line size hackBin Meng
Now that the RTL8169 driver warning is fixed we can drop this. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-19x86: Add an i8042 device for boards that have itSimon Glass
Some boards have an i8042 device. Enable the driver for all x86 boards, and add a device tree node for those which may have this keyboard. Also adjust the configuration so that i8042 is always separate from the VGA, and rename the stdin driver accordingly. With this commit the keyboard will not work, but it is fixed in the next commit. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-09x86: panther: Add PCI and video configurationSimon Glass
Add a PCI node to the device tree. This allows SPI flash and SATA to work correctly. Also configure the video to come up correctly even though there is no keyboard. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-04-16x86: Add support for panther (Asus Chromebox)Simon Glass
Support running U-Boot as a coreboot payload. Tested peripherals include: - Video (HDMI and DisplayPort) - SATA disk - Gigabit Ethernet - SPI flash USB3 does not work. This may be a problem with the USB3 PCI driver or something in the USB3 stack and has not been investigated So far this is disabled. The SD card slot also does not work. For video, coreboot will need to run the OPROM to set this up. With this board, bare support (running without coreboot) is not available as yet. Signed-off-by: Simon Glass <sjg@chromium.org>
