path: root/include/configs/chromebook_jerry.h
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-01-26video: add CONFIG_I2C_EDID and disable CONFIG_DISPLAY by defaultAnatolij Gustschin
Enabling CONFIG_DISPLAY breaks building for some architectures (microblaze-generic), so we disable CONFIG_DISPLAY in Kconfig by default and enable this option in defconfigs. CONFIG_DISPLAY depends on CONFIG_I2C_EDID, so add and enable it in defconfigs, too. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2016-01-21rockchip: jerry: Enable EDP and HDMI video outputSimon Glass
Enable these devices using the VOPL video output device. We explicitly disable VOPB in the device tree to avoid it taking over. Since this device has an LCD display this comes up by default. If the display fails for some reason then it will attempt to use HDMI. It is possible to force it to fail (and thus fall back to HDMI) by puting 'return -EPERM' at the top of rk_edp_probe(). For now there is no easy way to select between the two. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: jerry: Add support for timing SPI flash speedSimon Glass
Add the 'time' and 'sf test' commands so that we can test SPI flash performance. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: spl: Support full-speed CPU in SPLSimon Glass
Add a feature which speeds up the CPU to full speed in SPL to minimise boot time. This is only supported for certain boards (at present only jerry). Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: jerry: Enable the Chrome OS ECSimon Glass
Turn on the EC and enable the keyboard. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: jerry: Drop unused optionsSimon Glass
To reduce the SPL image size, drop the LED features. Jerry does not have an LED and we can leave out GPIO support also. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-08rockchip: Fix the configuration for chromebook_jerrySimon Glass
Various updates did not make it through to this board. Also the instructions for building a SPI image are no-longer correct. Fix these so that Jerry can boot to a prompt again. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: firefly: Save the environment on SD cardSjoerd Simons
Save the environment on the SD card for Firefly in the empty space between the SPL and the u-boot image. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-02rockchip: Add basic support for jerrySimon Glass
This builds and displays an SPL message, but does not function beyond that. Signed-off-by: Simon Glass <sjg@chromium.org>
