path: root/include/configs/cei-tk1-som.h
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-04-30power: Convert CONFIG_PMIC_AS3722 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_PMIC_AS3722 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30power: Rename CONFIG_AS3722_POWER to CONFIG_PMIC_AS3722Simon Glass
Before converting this to Kconfig, rename it to match the other PMICs. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-01ARM: tegra: Add support for TK1-SOM board from Colorado EngineeringPeter Chubb
The Colorado TK1 SOM is a small form factor board similar to the Jetson TK1. The main differences lie in the pinmux, and in that the PCIe controller is set to use in 4lanes+1lane, rather than 2+2. The pinmux header here was generated from a spreadsheet provided by Colorado Engineering using the tegra-pinmux scripts. The spreadsheet was converted from v09 to v11 by me. Signed-off-by: Peter Chubb <peter.chubb@data61.csiro.au> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
