path: root/include/configs/cardhu.h
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-28Revert "arm: Remove unregister MACH_TYPE_xxx uses"Tom Rini
This reverts commit 70b26cd057f42c7126088b49d4285955c8a00eae. This is not a strict revert as it is easier to fix board/atmark-techno/armadillo-800eva/armadillo-800eva.c to now the correct name (same value) than to revert that change too. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-14arm: Remove unregister MACH_TYPE_xxx usesTom Rini
Before we can sync with the latest mach-types.h file from the Linux Kernel we need to remove some instances of MACH_TYPE_xxx from our sources. As these values have been removed from the canonical upstream source we should not be using them either, so drop. Cc: Tom Warren <twarren@nvidia.com> Cc: Lucas Stach <dev@lynxeye.de> Cc: Luka Perkov <luka@openwrt.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Heiko Schocher <hs@denx.de> Cc: Thomas Weber <weber@corscience.de> Cc: Lucile Quirion <lucile.quirion@savoirfairelinux.com> Cc: Matthias Weisser <weisserm@arcor.de> Cc: Suriyan Ramasami <suriyan.r@gmail.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Nick Thompson <nick.thompson@gefanuc.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Erik van Luijk <evanluijk@interact.nl> Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-22net: Move CONFIG_RTL8169 to KconfigBin Meng
Introduce CONFIG_RTL8169 in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Stephen Warren <swaren@nvidia.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-12-01dm: pci: Avoid a driver model build error with CONFIG_CMD_PCI_ENUMSimon Glass
This is not supported with driver model, so print a message instead of generating a build error. Rescanning PCI is not yet implemented. This function will be implemented later once some additional PCI driver model improvements are merged. It was confirmed on the mailing list that no one on the tegra side will miss this feature, so it is disabled for tegra. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-12-01dm: tegra: pci: Move CONFIG_PCI_TEGRA to KconfigSimon Glass
Move this option to Kconfig and fix up all users. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-08-05configs: Remove CONFIG_SERIAL_MULTIStephen Warren
This config option isn't used anywhere at all. Remove all places that define/enable the option. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-03-04ARM: tegra: move common config defines centrallyStephen Warren
All boards need CONFIG_BOARD_EARLY_INIT_F, and many actively need CONFIG_BOARD_LATE_INIT. Move both of these into tegra-common.h so that board config headers don't need to repeatedly define them. Later commits will add new code in board_late_init() which applies to all boards, so CONFIG_BOARD_LATE_INIT should be enabled for all Tegra boards. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-18ARM: tegra: Enable PCIe on CardhuThierry Reding
The PCIe bus on Cardhu is routed to the dock connector. An ethernet NIC is available on the dock over the PCIe bus. Enable the PCIe controller and the network device driver so that the device can boot over the network. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-11dm: i2c: tegra: Convert to driver modelSimon Glass
This converts all Tegra boards over to use driver model for I2C. The driver is adjusted to use driver model and the following obsolete CONFIGs are removed: - CONFIG_SYS_I2C_INIT_BOARD - CONFIG_I2C_MULTI_BUS - CONFIG_SYS_MAX_I2C_BUS - CONFIG_SYS_I2C_SPEED - CONFIG_SYS_I2C This has been tested on: - trimslice (no I2C) - beaver - Jetson-TK1 It has not been tested on Tegra 114 as I don't have that board. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13ARM: tegra: use a CPU freq that all SKUs can supportStephen Warren
U-Boot on Tegra30 currently selects a main CPU frequency that cannot be supported at all on some SKUs, and needs higher VDD_CPU/VDD_CORE values on some others. This can result in unreliable operation of the main CPUs. Resolve this by switching to a CPU frequency that can be supported by any SKU. According to the following link, the maximum supported CPU frequency of the slowest Tegra30 SKU is 600MHz: repo http://nv-tegra.nvidia.com/gitweb/?p=linux-2.6.git;a=summary branch l4t/l4t-r16-r2 path arch/arm/mach-tegra/tegra3_dvfs.c table cpu_dvfs_table[] According to that same table, the minimum VDD_CPU required to operate at that frequency across all SKUs is 1.007V. Given the adjustment resolution of the TPS65911 PMIC that's used on all Tegra30-based boards we support, we'll end up using 1.0125V instead. At that VDD_CPU, tegra3_get_core_floor_mv() in that same file dictates that VDD_CORE must be at least 1.2V on all SKUs. According to tegra_core_speedo_mv() (in tegra3_speedo.c in the same source tree), that voltage is safe for all SKUs. An alternative would be to port much of the code from tegra3_dvfs.c and tegra3_speedo.c in the kernel tree mentioned above. That's more work than I want to take on right now. While all the currently supported boards use the same regulator chip for VDD_CPU, different types of regulators are used for VDD_CORE. Hence, we add some small conditional code to select how VDD_CORE is programmed. If this becomes more complex in the future as new boards are added, or we end up adding code to detect the SoC SKU and dynamically determine the allowed frequency and required voltages, we should probably make this a runtime call into a function provided by the board file and/or relevant PMIC driver. Cc: Alban Bedel <alban.bedel@avionic-design.de> Cc: Marcel Ziswiler <marcel@ziswiler.com> Cc: Bard Liao <bardliao@realtek.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-03ARM: tegra: set env vars to indicate Cardhu A04 supportStephen Warren
The U-Boot "cardhu" build supports only revision 4 of the Cardhu board and later compatible revisions. Hence, set $board_name in the default environment to "cardhu-a04" rather than just "cardhu". The Linux kernel has separate DTs for Cardhu A02 and A04, although the former isn't really supported any more. Consequently, the kernel DT file that matches the U-Boot cardhu build is "tegra30-cardhu-a04.dtb" rather than "tegra30-cardhu.dtb". Set the $fdtfile default environment variable to reflect this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-23tegra: i2c: Enable new CONFIG_SYS_I2C frameworkSimon Glass
This enables CONFIG_SYS_I2C on Tegra, updating existing boards and the Tegra i2c driver to support this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heiko Schocher <hs@denx.de>
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and serial. Conflicts: arch/arm/dts/exynos5250.dtsi Signed-off-by: Tom Rini <trini@ti.com>
2013-07-11Tegra: Config: Enable Tegra30/Tegra114 USB functionJim Lin
Add USB EHCI, storage and network support. Tested on Tegra30 Cardhu, and Tegra114 Dalmore platforms. All works well. Signed-off-by: Jim Lin <jilin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-06-13ARM: tegra: make use of negative ENV_OFFSET on NVIDIA boardsStephen Warren
Use a negative value of CONFIG_ENV_OFFSET for all NVIDIA reference boards that store the U-Boot environment in the 2nd eMMC boot partition. This makes U-Boot agnostic to the size of the eMMC boot partition, which can vary depending on which eMMC device was actually stuffed into the board. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-03-25tegra: spi: rename tegra SPI driversAllen Martin
Rename tegra SPI drivers to tegra20_flash and tegra20_slink in preparation for commonization and addition of tegra114_spi. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14ARM: tegra: enable a common set of disk-related commands everywhereStephen Warren
Enable a common set of partition types, filesystems, and related commands in tegra-common.h, so that they are available on all Tegra boards. This allows boot.scr (loaded and executed by the default built-in environment) on those boards to assume that certain features are always available. Do this in tegra-common.h, so that individual board files can undefine the features if they really don't want any of them. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-03-14Tegra30: MMC: Enable DT MMC driver support for Tegra30 Cardhu boardsTom Warren
Tested on my Cardhu-A04 tablet, eMMC and SD-Card work fine, can load a kernel off of an SD card OK, card detect works, and the env is now stored in eMMC (end of the 2nd 'boot' sector, same as Tegra20). Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-02-11tegra: cardhu: config: enable SPIAllen Martin
Turn on SPI in cardhu config file Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-01-16Tegra30: I2C: Enable I2C driver on CardhuTom Warren
Tested all 5 'buses', i2c probe enumerates device addresses on all but dev 4 (I2C4) [no devices on that bus on my Cardhu]. Note that this uses the extant tegra_i2c.c driver w/o modification. Signed-off-by: Tom Warren <twarren@nvidia.com>
