path: root/include/configs/canyonlands.h
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-11-21ppc4xx: Changed 460EX/GT OCM TLB and internal SRAM initializationDave Mitchell
Expanded OCM TLB to allow access to 64K OCM as well as 256K of internal SRAM. Adjusted internal SRAM initialization to match updated user manual recommendation. OCM & ISRAM are now mapped as follows: physical virtual size ISRAM 0x4_0000_0000 0xE300_0000 256k OCM 0x4_0004_0000 0xE304_0000 64k A single TLB was used for this mapping. Signed-off-by: Dave Mitchell <dmitch71@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-31ppc4xx: Correctly configure the GPIO pin muxing on ArchesStefan Roese
Arches doesn't use PerCS3 but GPIO43, so let's configure the GPIO pin multiplexing correctly Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21ppc4xx: Add AMCC Arches board support (dual 460GT)Adam Graham
The Arches Evaluation board is based on the AMCC 460GT SoC chip. This board is a dual processor board with each processor providing independent resources for Rapid IO, Gigabit Ethernet, and serial communications. Each 460GT has it's own 512MB DDR2 memory, 32MB NOR FLASH, UART, EEPROM and temperature sensor, along with a shared debug port. The two 460GT's will communicate with each other via shared memory, Gigabit Ethernet and x1 PCI-Express. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-09-10rename CFG_ENV_IS_IN_NAND in CONFIG_ENV_IS_IN_NANDJean-Christophe PLAGNIOL-VILLARD
2008-06-06ppc4xx: Unify AMCC's board config files (part 2/3)Stefan Roese
This patch series unifies the AMCC eval board ports by introducing a common include header for all AMCC eval boards: include/configs/amcc-common.h This header now includes all common configuration options/defines which are removed from the board specific headers. The reason for this is ease of maintenance and unified look and feel of all AMCC boards. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-22ppc4xx: Fix Canyonlands and Glacier default environment for fdt usageStefan Roese
This patch fixes the Canyonlands and Glacier default environment to better fit to the arch/powerpc device-tree kernels. The variables dealing with arch/ppc booting are removed, since these boards are supported only in arch/powerpc. Glacier uses the same config file as Canyonlands. Also, the Glacier now uses non-FPU rootpath, since 460GT has no FPU. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-18ppc4xx: Change Canyonlands to support booting from 2k page NAND devicesStefan Roese
2008-04-09ppc4xx: Fix Canyonlands default environment to work with new image supportStefan Roese
Since the new image support checks for image overwriting, the default environment needs to get adjusted to use correct addresses. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-28ppc4xx: Canyonlands: Print SATA/PCIe configuration and board revisionStefan Roese
Canyonlands (460EX) shares the first PCIe interface with the SoC SATA interface. This usage can be configured with the jumper J6. This patch displays the current configuration upon bootup and changes the PCIe init loop, to only initialize the availabel PCIe slots. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-27ppc4xx: Add AMCC Glacier 406GT eval board supportStefan Roese
This patch adds support for the AMCC Glacier 460GT eval board. The main difference to the Canyonlands board are listed here: - 4 ethernet ports instead of 2 - no SATA port - no USB port Currently EMAC2+3 are not working. This will be fixed in a later release. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add USB OHCI support to AMCC Canyonlands 460EX eval boardStefan Roese
This patch adds USB OHCI support to the Canyonlands board port. It also enables EXT2 support. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add Canyonlands NAND booting supportStefan Roese
460EX doesn't support a fixed bootstrap option to boot from 512 byte page NAND devices. The only bootstrap option for NAND booting is option F for 2k page devices. So to boot from a 512 bype page device, the I2C bootstrap EEPROM needs to be programmed accordingly. This patch adds basic NAND booting support for the AMCC Canyonlands aval board and also adds support to the "bootstrap" command, to enable NAND booting I2C setting. Tested with 512 byte page NAND device (32MByte) on Canyonlands. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add AMCC Canyonlands support (460EX) (2/3)Stefan Roese
This patch adds support for the AMCC Canyonlands 460EX evaluation board. Signed-off-by: Stefan Roese <sr@denx.de>
