path: root/include/configs/canmb.h
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2009-02-09net: removed board-specific CONFIGs from MPC5xxx FEC driverBen Warren
Added new CONFIG options for the three type of MAC-PHY interconnect and applied them all relevant board config files Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-07-10include/configs/[a-e]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various c* named board config files.Jon Loeliger
2007-05-27MPC5xxx: Change names of defines related to IPB and PCI clocks.Bartlomiej Sieka
Both CFG_PCISPEED_66 and CFG_IPBSPEED_133 are misnamed, as defining them does not cause PCI or IPB clocks to run at the specified speed. Instead, they configure divisors used to calculate said clocks. This patch renames the defines according to their real function. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2005-04-21Fix bug in the SDRAM initialization code for canmb, IceCube andwdenk
PM520 boards. Fix PHY address for canmb board.
2005-04-20Auto-size RAM on canmb board.wdenk
Cleanup.
2005-04-13Add support for canmb boardLABEL_2005_04_14_0115wdenk
