The current ca9x4_ct_vxp platform contains support for a Versatile
Express motherboard with a quad core A9 core tile.
This patch separates the Versatile Express motherboard code and the
A9 specific code, to ease supporting more core tiles in the next
patches.
Andre: merged the first two of Ryan's original patches and did some
checkpatch fixes.
Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org>
Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
This patch provides a support to use buffered writes on flash
for versatile and vexpress boards.
This will certainly increase the flash writes.
Signed-off-by: Jagannadha Sutradharudu Teki <402jagan@gmail.com>
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present
in most ARM board config files.
IRQs are only enabled for 1 config, so remove the unused config options
for IRQ and FIQ stack size as well.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
Cc: Matt Waddel <matt.waddel@linaro.org>
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
Signed-off-by: Christopher Harvey <charvey@matrox.com>
Replace the cache related CONFIG flags with more meaningful
names. Following are the changes:
CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_NO_ICACHE -> CONFIG_SYS_ICACHE_OFF
CONFIG_SYS_NO_DCACHE -> CONFIG_SYS_DCACHE_OFF
Signed-off-by: Aneesh V <aneesh@ti.com>
V2:
* Changed CONFIG_L2_OFF -> CONFIG_SYS_NO_L2CACHE
V4:
* Changed all three flags to the final names suggested as above
and accordingly changed the commit message
Added the board specific definitions to use the MMCI device.
Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
The following boards gain device tree support with this patch:
ca9x4_ct_vxp - Versatile Express
i.mx5 boards:
efikamx
mx51evk
mx53evk
OMAP boards:
devkit8000
igep0020
igep0030
omap3_overo
omap3_pandora
omap4_sdp3430
omap3_zoom1
omap3_zoom2
omap4_panda
omap4_sdp4430
Tegra boards:
Harmony
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Remove obsolete board config.mk.
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Adds support for the ARM quad-core Cortex-A9 processor
This system includes a motherboard(Versatile Express), daughterboard
(Coretile), and SOC(Cortex-A9 quad core). The serial port, ethernet,
and flash systems work with these additions. The naming convention
is:
SOC -> CortexA9 quad core = ca9x4
daughterboard -> Coretile = ct
motherboard -> Versatile Express = vxp
This gives ca9x4_ct_vxp.c as the board support file.
