path: root/include/configs/c2mon.h
2012-10-28PPC: remove dead boards (AMX860, c2mon, ETX094, IAD210, LANTEC, SCM)Wolfgang Denk
These boards have long reached EOL, and there has been no indication of any active users of such hardware for years. Get rid of the dead weight. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Wolfgang Grandegger <wg@denx.de>
2012-10-17split mpc8xx hooks from cmd_ide.cPavel Herrmann
move most of mpc8xx hooks from cmd_ide.c into ide_preinit() and newly created ide_init_postreset() (invoked after calling ide_reset after ide_preinit), some cleanup to make checkpatch happy, enable IDE init hooks in configs of affected boards. confusingly, these hooks are used by more than just mpc8xx-based boards, and therefore are placed in arch/ppc/lib/ note: checkpatch still emits warnings about using volatile Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-07-09include/configs/[a-m]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various c* named board config files.Jon Loeliger
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2002-08-19Initial revisionwdenk
