path: root/include/configs/bur_am335x_common.h
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-10Convert CONFIG_SYS_I2C_OMAP24XX to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_OMAP24XX Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-06-09am33xx: Finish migration of CONFIG_AM33XX/AM43XXTom Rini
Almost all users of CONFIG_AM33XX/AM43XX have been migrated. Finish moving the last few over to Kconfig, and put all of the boards under the appropriate Kconfig chocie now. This board choice is non-optional, so remove that keyword on am33xx. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15gpio: Move OMAP_GPIO to KconfigTom Rini
This driver is used often enough such that we want to have this enabled by default on any ARCH_OMAP2PLUS board, and this only compiles on ARCH_OMAP2PLUS due to required defines, so mark that as the depends. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15TI: Drop 'CONFIG_OMAP'Tom Rini
In the two cases in the code where we use CONFIG_OMAP as a useful test currently we can make use of CONFIG_ARCH_OMAP2PLUS instead. With that changed we can drop all defines of CONFIG_OMAP. While in here, CONFIG_OMAP3430 is only defined and then never used, so drop. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-11configs: am335x_evm: Use omap2 generic spl load scriptLokesh Vutla
No reason to use a separate load script for am33xx than using omap-common load script. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-21TI: Remove CONFIG_OMAP_COMMON in favor of CONFIG_ARCH_OMAP2Tom Rini
With the move to arch/arm/mach-omap2 there are now very few uses of CONFIG_OMAP_COMMON and further they can all be replaced with CONFIG_ARCH_OMAP2, so do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-21arm: Introduce arch/arm/mach-omap2 for OMAP2 derivative platformsTom Rini
This moves what was in arch/arm/cpu/armv7/omap-common in to arch/arm/mach-omap2 and moves arch/arm/cpu/armv7/{am33xx,omap3,omap4,omap5} in to arch/arm/mach-omap2 as subdirectories. All refernces to the former locations are updated to the current locations. For the logic to decide what our outputs are, consolidate the tests into a single config.mk rather than including 4. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_YMODEM_SUPPORT to KconfigSimon Glass
Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig Move this option to Kconfig and tidy up existing uses. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-09-06TI: Rework SRAM definitions and maximumsTom Rini
On all TI platforms the ROM defines a "downloaded image" area at or near the start of SRAM which is followed by a reserved area. As it is at best bad form and at worst possibly harmful in corner cases to write in this reserved area, we stop doing that by adding in the define NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this. At current we define the end of scratch space at 0x228 bytes past the start of scratch space this this gives us a lot of room to grow. As these scratch uses are non-optional today, all targets are modified to respect this boundary. Tested on OMAP4 Pandaboard, OMAP3 Beagle xM Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Paul Kocialkowski <contact@paulk.fr> Cc: Enric Balletbo i Serra <eballetbo@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Weber <weber@corscience.de> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Heiko Schocher <hs@denx.de> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: "B, Ravi" <ravibabu@ti.com> Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: "Kipisz, Steven" <s-kipisz2@ti.com> Cc: Daniel Allred <d-allred@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Ladislav Michl <ladis@linux-mips.org>
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2016-02-24board/BuR: split bur_am335x_common.h into am335x-specific and BuR common partsHannes Schmelzer
bur_am335x_common.h today holds all common configuration which is shared over all B&R boards. In future we want to bring up boards which are not based on AM335x only but we still want to have common configuration over all B&R boards independent from their architecture. To prepare this we introduce a new file "bur_cfg_common.h", where we move all common things, which are not architecture specific, from bur_am335x_common.h. On B&R am335x boards we include from now: #include <configs/bur_cfg_common.h> #include <configs/bur_am335x_common.h> On other B&R boards, we include only #include <configs/bur_cfg_common.h> Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24board/BuR: move everything possible from board's headerfile to KConfigHannes Schmelzer
We drop everything possible things from board headerfiles and replace this functionality with responsible settings in Kconfig (_defconfig). Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24board/BuR: drop ETH-support in SPL-StageHannes Schmelzer
During very early prototype-phase we did boot the AM335x boards initially from CPSW-EMAC. Now we don't need this feature anymore. So we drop it to save MLO-space and having therefore a more quickly boot. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-09-11board/BuR: simplify default IP-setup on B&R boards.Hannes Petermaier
To simplify and having a common default IP-setup on all B&R boards we introduce an environment variable "brdefaultip" which does following. Test if ${ipaddr} is empty, if yes it set's up some defaults: - ipaddr : 192.168.60.1 - netmask : 255.255.255.0 - gatewayip: 192.168.60.254 - serverip : 192.168.60.254 This environment is ran from CONFIG_PREBOOT. All other "tricks" are dropped. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-06-02board/BuR/common: fix netconsoleHannes Schmelzer
netconsole had become defective over time and cleanups. Because the feature is used very rarely nobody did take notice about this defect. With this patch the resulting syntax error on call will be fixed. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2015-06-02Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
Fixup include/configs/unipher.h to not set CONFIG_LIB_RAND Signed-off-by: Tom Rini <trini@konsulko.com>
2015-05-28cosmetic: change Author/MAINTAINER Name from Petermaier to SchmelzerHannes Schmelzer
Since i've been married, i also have a new surname. Mr. Petermaier moved to Mr. Schmelzer. In this patch i update all files in which my (old) name is present. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2015-05-08board/BuR/common: rename "usbupdate" environment to "usbscript"Hannes Petermaier
usbupdate in real does allways load some script from usb-storage and execute it, on all B&R targets. So we do following 2 things: - rename it to what it really does - move it from boards to common environment Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-05-08board/BuR/common: remove BMP_DISPLAY from tseries boardHannes Petermaier
Since we display in future the splash screen out of linux-os, we don't need this support anymore within the common section. But kwb-target is still using BMP_DISPLAY feature, so we move the related from the common section into the target-specific. Also the default environment of tseries will be adapted to this. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-17board/BuR/common: use SYS_CONSOLE_OVERWRITEHannes Petermaier
We don't want that CONSOLE is redirected to LCD upon init, we rather prefer that console is still on the serial line. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-16board/BuR/common: fix compiler warningHannes Petermaier
Signed-off-by: Hannes Petermaier <hannes.petermaier@br-automation.com> Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/common: Add support for displaying BMP on LCDHannes Petermaier
Customer wants to display some logo very quickly after power on, so we support from now loading a compressed bmp.gz to the screen. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/common: Enable CONFIG_CMD_TIMEHannes Petermaier
time measurement of u-boot commands is needed very often during development. We add this feature until development is completed. Maybe forever :) Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/common: Introduce Network Console and common environment for itHannes Petermaier
It is often necessary to "break in" into boards bootloader commandline if something fails or even for development purposes some parameters have to be changed. So we enable u-boot's CONFIG_NETCONSOLE feature. We also modify Networksettings to apply with this new use-case. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-04ti: armv7: Move SPL SDRAM init to the right place, drop unused CONFIG_SPL_STACKSimon Glass
Currently in some cases SDRAM init requires global_data to be available and soon this will not be available prior to board_init_f(). Adjust the code paths in these cases to be correct. In some cases we had the SPL stack be in DDR as we might have large stacks (due to Falcon Mode + Environment). In these cases switch to CONFIG_SPL_STACK_R. In other cases we had simply been setting CONFIG_SPL_STACK into SRAM. In these cases we no longer need to (CONFIG_SYS_INIT_SP_ADDR is used and is also in SRAM) so drop those lines. Signed-off-by: Simon Glass <sjg@chromium.org> Tested on Beagleboard, Beagleboard xM Tested-by: Matt Porter <mporter@konsulko.com> Tested on Beaglebone Black, AM43xx GP EVM, OMAP5 uEVM, OMAP4 Pandaboard Tested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-09-24kconfig: move CONFIG_CMD_CRC32 to KconfigMasahiro Yamada
Since CONFIG_CMD_CRC32 is defined in config_cmd_defaults.h, it is enabled for all the boards except the ones undefining it explicitly: kwb tseries_mmc tseries_nand tseries_spi vct_platinum_onenand_small vct_platinum_small vct_platinumavc_onenand_small vct_platinumavc_small vct_premium_onenand_small vct_premium_small The default value of this config option should be "y" and "# CONFIG_CMD_CRC32 is not set" should be added for those exceptions. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-06-06board/BuR/common: Add CONFIG_CMD_I2CHannes Petermaier
in almost all cases we need the i2c commands within the u-boot shell. So we enable them within the common section. Cc: trini@ti.com Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2014-06-06board/BuR/common: introduce usage of CONFIG_SYS_GENERIC_BOARDHannes Petermaier
2014-03-31board: enable 32kHz RTC OSC at B&R boardsHannes Petermaier
Since RTC-Clock is needed on all B&R boards, the OSC will be enabled wihtin SPL-stage. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2014-03-04drivers: net: cpsw: add support to have phy address from cpsw platform dataMugunthan V N
Some platforms like AM437x have different EVMs with different phy addresses, so this patch adds support for passing phy address via cpsw plaform data. Also renamed phy_id to phy_addr so better understanding of the code. Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> [trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335 pengwyn boards] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21board: Add support for B&R T-Series MotherboardHannes Petermaier
Adds support for Bernecker & Rainer Industrieelektronik GmbH T-Series Motherboard, using TI's AM3352 SoC. Most of code is derived from TI's AM335x_EVM Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
