path: root/include/configs/bur_am335x_common.h
2015-09-11board/BuR: simplify default IP-setup on B&R boards.Hannes Petermaier
To simplify and having a common default IP-setup on all B&R boards we introduce an environment variable "brdefaultip" which does following. Test if ${ipaddr} is empty, if yes it set's up some defaults: - ipaddr : 192.168.60.1 - netmask : 255.255.255.0 - gatewayip: 192.168.60.254 - serverip : 192.168.60.254 This environment is ran from CONFIG_PREBOOT. All other "tricks" are dropped. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-06-02board/BuR/common: fix netconsoleHannes Schmelzer
netconsole had become defective over time and cleanups. Because the feature is used very rarely nobody did take notice about this defect. With this patch the resulting syntax error on call will be fixed. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2015-06-02Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
Fixup include/configs/unipher.h to not set CONFIG_LIB_RAND Signed-off-by: Tom Rini <trini@konsulko.com>
2015-05-28cosmetic: change Author/MAINTAINER Name from Petermaier to SchmelzerHannes Schmelzer
Since i've been married, i also have a new surname. Mr. Petermaier moved to Mr. Schmelzer. In this patch i update all files in which my (old) name is present. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2015-05-08board/BuR/common: rename "usbupdate" environment to "usbscript"Hannes Petermaier
usbupdate in real does allways load some script from usb-storage and execute it, on all B&R targets. So we do following 2 things: - rename it to what it really does - move it from boards to common environment Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-05-08board/BuR/common: remove BMP_DISPLAY from tseries boardHannes Petermaier
Since we display in future the splash screen out of linux-os, we don't need this support anymore within the common section. But kwb-target is still using BMP_DISPLAY feature, so we move the related from the common section into the target-specific. Also the default environment of tseries will be adapted to this. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-17board/BuR/common: use SYS_CONSOLE_OVERWRITEHannes Petermaier
We don't want that CONSOLE is redirected to LCD upon init, we rather prefer that console is still on the serial line. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-16board/BuR/common: fix compiler warningHannes Petermaier
Signed-off-by: Hannes Petermaier <hannes.petermaier@br-automation.com> Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/common: Add support for displaying BMP on LCDHannes Petermaier
Customer wants to display some logo very quickly after power on, so we support from now loading a compressed bmp.gz to the screen. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/common: Enable CONFIG_CMD_TIMEHannes Petermaier
time measurement of u-boot commands is needed very often during development. We add this feature until development is completed. Maybe forever :) Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/common: Introduce Network Console and common environment for itHannes Petermaier
It is often necessary to "break in" into boards bootloader commandline if something fails or even for development purposes some parameters have to be changed. So we enable u-boot's CONFIG_NETCONSOLE feature. We also modify Networksettings to apply with this new use-case. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-04ti: armv7: Move SPL SDRAM init to the right place, drop unused CONFIG_SPL_STACKSimon Glass
Currently in some cases SDRAM init requires global_data to be available and soon this will not be available prior to board_init_f(). Adjust the code paths in these cases to be correct. In some cases we had the SPL stack be in DDR as we might have large stacks (due to Falcon Mode + Environment). In these cases switch to CONFIG_SPL_STACK_R. In other cases we had simply been setting CONFIG_SPL_STACK into SRAM. In these cases we no longer need to (CONFIG_SYS_INIT_SP_ADDR is used and is also in SRAM) so drop those lines. Signed-off-by: Simon Glass <sjg@chromium.org> Tested on Beagleboard, Beagleboard xM Tested-by: Matt Porter <mporter@konsulko.com> Tested on Beaglebone Black, AM43xx GP EVM, OMAP5 uEVM, OMAP4 Pandaboard Tested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-09-24kconfig: move CONFIG_CMD_CRC32 to KconfigMasahiro Yamada
Since CONFIG_CMD_CRC32 is defined in config_cmd_defaults.h, it is enabled for all the boards except the ones undefining it explicitly: kwb tseries_mmc tseries_nand tseries_spi vct_platinum_onenand_small vct_platinum_small vct_platinumavc_onenand_small vct_platinumavc_small vct_premium_onenand_small vct_premium_small The default value of this config option should be "y" and "# CONFIG_CMD_CRC32 is not set" should be added for those exceptions. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-06-06board/BuR/common: Add CONFIG_CMD_I2CHannes Petermaier
in almost all cases we need the i2c commands within the u-boot shell. So we enable them within the common section. Cc: trini@ti.com Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2014-06-06board/BuR/common: introduce usage of CONFIG_SYS_GENERIC_BOARDHannes Petermaier
2014-03-31board: enable 32kHz RTC OSC at B&R boardsHannes Petermaier
Since RTC-Clock is needed on all B&R boards, the OSC will be enabled wihtin SPL-stage. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2014-03-04drivers: net: cpsw: add support to have phy address from cpsw platform dataMugunthan V N
Some platforms like AM437x have different EVMs with different phy addresses, so this patch adds support for passing phy address via cpsw plaform data. Also renamed phy_id to phy_addr so better understanding of the code. Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> [trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335 pengwyn boards] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21board: Add support for B&R T-Series MotherboardHannes Petermaier
Adds support for Bernecker & Rainer Industrieelektronik GmbH T-Series Motherboard, using TI's AM3352 SoC. Most of code is derived from TI's AM335x_EVM Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
