path: root/include/configs/broadcom_bcm968580xref.h
2019-04-22bcm968580xref: add nand supportPhilippe Reynes
Enable the nand support (driver and command) in the configuration of the board bcm968580xref. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2018-11-16bcm968580xref: add initial supportPhilippe Reynes
This add the initial support of the broadcom reference board bcm968580xref with a bcm6858 SoC. This board has 512 MB of ram, 256 MB of flash (nand), 2 usb port, 1 uart, 4 ethernet ports (LAN), 1 ethernet port (WAN). Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
