path: root/include/configs/bmips_bcm6838.h
2018-08-08bcm6838: add initial supportPhilippe Reynes
This adds the initial support of the Broadcom BCM6838 SoC familly, only cpu, dram, uart and leds are supported. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
