path: root/include/configs/bmips_bcm6368.h
2018-03-21mips: bmips: add support for bcm6368 usbÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
2018-01-26MIPS: add support for Broadcom MIPS BCM6368 SoC familyÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
