path: root/include/configs/bluestone.h
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2010-10-04APM821xx: Add bluestone board supportTirumala Marri
Add support code for bluestone board wth APM821XX processor based. This patch includes early board init, misc init, configure EBC, initializes UIC, MAKEALL, board.cfg and MAINTAINERS file. Signed-off-by: Tirumala R Marri <tmarri@apm.com Signed-off-by: Stefan Roese <sr@denx.de>
