path: root/include/configs/bluestone.h
2010-10-04APM821xx: Add bluestone board supportTirumala Marri
Add support code for bluestone board wth APM821XX processor based. This patch includes early board init, misc init, configure EBC, initializes UIC, MAKEALL, board.cfg and MAINTAINERS file. Signed-off-by: Tirumala R Marri <tmarri@apm.com Signed-off-by: Stefan Roese <sr@denx.de>
