This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Correct spelling of "U-Boot" shall be used in all written text
(documentation, comments in source files etc.).
Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards.
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
We really don't want boards defining fixed MAC addresses in their config
so we just remove the option to set it in a fixed way. If you must have
a MAC address that was not provisioned, then use the random MAC address
functionality.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
In case only the CONFIG_SYS_I2C_SPEED is set in configuration file,
the CONFIG_SYS_I2C_SOFT_SPEED is defined as CONFIG_SYS_I2C_SPEED.
The CONFIG_SYS_I2C_SOFT_SPEED is then used throughout the driver.
Unfortunatelly, due to a typo in the driver, instead of defining
CONFIG_SYS_I2C_SOFT_SPEED, an CONFIG_SYS_SOFT_I2C_SPEED was defined
and therefore the driver failed to compile. The same applies for
CONFIG_SYS_I2C_SOFT_SLAVE , where the swap happens as well.
This patch fixes the issue.
- added to soft_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
Kill multiple occurances and redeclaration of MK_STR
in favor of __stringify().
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code.
The CONFIG_BFIN_CPU option is largely used in the build system, so move
it out of the board config.h and into the board config.mk. It'd be nice
to keep everything in the config.h, but the patch to extract that value
early was rejected.
Use the new common gpio framework to simplify and unify the soft i2c
configuration settings.
Acked-by: Heiko Schocher <hs@denx.de>
All in-tree boards that use this controller have CONFIG_NET_MULTI
added
Also:
- changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111
- cleaned up line lengths
- modified all boards that override weak function in this driver
- modified all eeprom standalone apps to work with new driver
- updated blackfin standalone EEPROM app after testing
The latest blackstamp boards can only run the SPI flash at 15MHz before
they start to crap out, so lower the max speeds accordingly. The new SPI
flash also has different sector requirements, so update the environment
sizes as well.
The SPI flash define is named CONFIG_SF_DEFAULT_SPEED, not
CONFIG_SF_DEFAULT_HZ, so fix the typos in the Blackfin boards.
The Blackfin port was using asm/blackfin-config-{pre,post}.h to setup
common Blackfin board defines. The common method now is to use config.h,
so convert blackfin-config-post.h to that. Rename the still Blackfin
specific blackfin-config-pre.h to config-pre.h so the naming conventions
at least line up.
