This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards.
them from include/configs.
NET_RANDOM_ETHADDR depends on lib/rand.c. This patch adds dependency to
Kconfig to ensure that library is also compiled.
Remove the definitions from Blackfin boards' include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com>
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
New configs:
- CONFIG_LIB_RAND - to enable implementation of rand library in lib/rand.c
- CONFIG_LIB_HW_RAND - to enable hardware based implementations of lib rand
Other changes:
- add CONFIG_LIB_RAND to boards configs which needs rand()
- put only one rand.o dependency in lib/Makefile
CONFIG_LIB_HW_RAND should be defined for drivers which implements rand library
(declared in include/common.h):
- void srand(unsigned int seed)
- unsigned int rand(void)
- unsigned int rand_r(unsigned int *seedp)
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Michael Walle <michael@walle.cc>
Cc: Tom Rini <trini@ti.com>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
- added to soft_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
The gpio spec for bf54x and bf60x differ a lot from the old gpio driver for bf5xx.
A lot of machine macros are used to accomodate both code in one gpio driver.
This patch split the old gpio driver and move new gpio2 support to the generic
gpio driver folder.
- To enable gpio2 driver, macro CONFIG_ADI_GPIO2 should be defined in the board's
config header file.
- The gpio2 driver supports bf54x, bf60x and future ADI processors, while the
older gpio driver supports bf50x, bf51x, bf52x, bf53x and bf561.
- All blackfin specific gpio function names are replaced by the generic gpio APIs.
- Move blackfin serial driver to the generic driver folder.
- Move blackfin serial headers to blackfin arch head folder.
- Update the include path to blackfin serial header in start up code.
- Enable hw_watchdog_init() in watchdog.h if CONFIG_HW_WATCHDOG is defined.
- Move blackfin hw watchdog driver to the generic driver folder.
- Call hw_watchdog_init() from blackfin board init code.
- Reuse macro CONFIG_WATCHDOG_TIMEOUT_MSECS
- Update README.watchdog accordingly
Remove blackfin specific implementation of the generic serial API when
early print macro is defined.
In BFIN_BOOT_BYPASS mode, don't call generic serial_puts, because
early print in bypass mode is running before code binary is relocated
to the link address.
Board and config header files for bf609-ezkit support.
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
Remove any notion of CONFIG_SERIAL_MULTI from board config files.
Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless
to specify this config option in the board config files. Therefore
remove it.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Rework the emulation of serial console via JTAG from simple ad-hoc
implementation of serial port routines to CONFIG_SERIAL_MULTI and
enable CONFIG_SERIAL_MULTI unconditionally for blackfin.
In order for the JTAG serial console to take precedence over all
other serial ports available in system, implement override for
default_serial_console call returning this JTAG serial console.
This brings in a bit of a growth of size, but eventually will allow
us to unconditionally enable CONFIG_SERIAL_MULTI throughout the whole
U-Boot and maintain only one serial subsystem.
Cc: Mike Frysinger <vapier@gentoo.org>
Kill multiple occurances and redeclaration of MK_STR
in favor of __stringify().
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
The few tests that are Blackfin-specific have been migrated to common
code or been rewritten with the existing "bsp-specific" defines.
For only ~150 bytes increase in size, we can get a nice flash progress
indicator rather than just the boring dots (which don't tell too much
about overall progress). So enable it for all ADI boards.
Since this only adds less than 3KiB, enable for all ADI boards.
Switch to the new common mmc_spi driver.
Our monitor is always in RAM, so enable this define for the CFI layer.
This define isn't used anywhere anymore, so punt it.
The current size used (256KiB) is smaller than the LDR created for
the bf548-ezkit, so 'run update' doesn't work correctly. So bump
up the size a bit by making this flexible per-board config.
We use the lock/unlock options in our default nand code, so enabl
support for the options.
Reported-by: Vivi Li <vivi.li@analog.com>
Let people easily override bootdelay and network settings.
- Revives POST for blackfin arch;
- Removes redundant code:
arch/blackfin/lib/post.c
arch/powerpc/cpu/ppc4xx/commproc.c
arch/powerpc/cpu/mpc512x/common.c
- fixes up the post_word_{load|store} usage.
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com>
Acked-by: Detlev Zundel <dzu@denx.de>
Tested-by: Anatolij Gustschin <agust@denx.de>
List of the maintainers of the affected by patch boards:
Cc: Stephan Linz <linz@li-pro.net>
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Cc: Larry Johnson <lrj@acm.org>
Cc: Feng Kan <fkan@amcc.com>
Use the new common gpio framework to simplify and unify the soft i2c
configuration settings.
Acked-by: Heiko Schocher <hs@denx.de>
Rather than only support the pins dedicated as chip selects, utilize the
gpio framework to support any gpio pin.
Now that we have a unified gpio layer, the misc partial gpio commands
can be unified and made complete (support all possible gpios).
Signed-off-by: Robin Getz <robin.getz@analog.com>
Very little additional code overhead, and only works when the user sets an
env var ahead of time, so default to on makes sense.
The tinyboards like to run at a little lower voltage than the default, and
they prefer to boot over the network. For the latter, extend the common
code a little to make this easier.
Also fix the cm-bf527 env sector size while we're in here to reflect the
flash that is actually in use.
Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at>
There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
The Linux kernel has changed the way it numbers serial ports, so update
the default command line to match it.
Since the NAND code now uses 64bit code, make sure we enable support for
ADI Blackfin boards in printf to avoid the warning:
nand_util.c:45:2: warning: #warning Please define CONFIG_SYS_64BIT_VSPRINTF for correct output!
