path: root/include/configs/bfin_adi_common.h
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-13autoboot: follow-up cleanup after CONFIG_BOOTDELAY movesMasahiro Yamada
Tidy up garbage left by commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY into a Kconfig option"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-06-01net: Fix NET_RANDOM_ETHADDR dependenciesMichal Simek
NET_RANDOM_ETHADDR depends on lib/rand.c. This patch adds dependency to Kconfig to ensure that library is also compiled. Remove the definitions from Blackfin boards' include/configs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2014-11-17blackfin: convert to use CONFIG_SYS_I2C frameworkScott Jiang
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com>
2014-11-10bfin: the max bfin sdh block count is 127Sonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2014-03-28lib: rand: introduce new configs: CONFIG_LIB_RAND and CONFIG_LIB_HW_RANDPrzemyslaw Marczak
New configs: - CONFIG_LIB_RAND - to enable implementation of rand library in lib/rand.c - CONFIG_LIB_HW_RAND - to enable hardware based implementations of lib rand Other changes: - add CONFIG_LIB_RAND to boards configs which needs rand() - put only one rand.o dependency in lib/Makefile CONFIG_LIB_HW_RAND should be defined for drivers which implements rand library (declared in include/common.h): - void srand(unsigned int seed) - unsigned int rand(void) - unsigned int rand_r(unsigned int *seedp) Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Michael Walle <michael@walle.cc> Cc: Tom Rini <trini@ti.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-05-13bfin: Move gpio support for bf54x and bf60x into the generic driver folder.Sonic Zhang
The gpio spec for bf54x and bf60x differ a lot from the old gpio driver for bf5xx. A lot of machine macros are used to accomodate both code in one gpio driver. This patch split the old gpio driver and move new gpio2 support to the generic gpio driver folder. - To enable gpio2 driver, macro CONFIG_ADI_GPIO2 should be defined in the board's config header file. - The gpio2 driver supports bf54x, bf60x and future ADI processors, while the older gpio driver supports bf50x, bf51x, bf52x, bf53x and bf561. - All blackfin specific gpio function names are replaced by the generic gpio APIs. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2013-05-13blackfin: Move blackfin serial driver out of blackfin arch folder.Sonic Zhang
- Move blackfin serial driver to the generic driver folder. - Move blackfin serial headers to blackfin arch head folder. - Update the include path to blackfin serial header in start up code. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2013-05-13blackfin: Move blackfin watchdog driver out of the blackfin arch folder.Sonic Zhang
- Enable hw_watchdog_init() in watchdog.h if CONFIG_HW_WATCHDOG is defined. - Move blackfin hw watchdog driver to the generic driver folder. - Call hw_watchdog_init() from blackfin board init code. - Reuse macro CONFIG_WATCHDOG_TIMEOUT_MSECS - Update README.watchdog accordingly Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2013-05-13blackfin: Enable early print via the generic serial API.Sonic Zhang
Remove blackfin specific implementation of the generic serial API when early print macro is defined. In BFIN_BOOT_BYPASS mode, don't call generic serial_puts, because early print in bypass mode is running before code binary is relocated to the link address. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2013-03-04blackfin: bf60x: add board and headers files to support bf609Sonic Zhang
Board and config header files for bf609-ezkit support. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15serial: bfin: Flip the jtag serial console to CONFIG_SERIAL_MULTIMarek Vasut
Rework the emulation of serial console via JTAG from simple ad-hoc implementation of serial port routines to CONFIG_SERIAL_MULTI and enable CONFIG_SERIAL_MULTI unconditionally for blackfin. In order for the JTAG serial console to take precedence over all other serial ports available in system, implement override for default_serial_console call returning this JTAG serial console. This brings in a bit of a growth of size, but eventually will allow us to unconditionally enable CONFIG_SERIAL_MULTI throughout the whole U-Boot and maintain only one serial subsystem. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29Blackfin: post: drop custom test listMike Frysinger
The few tests that are Blackfin-specific have been migrated to common code or been rewritten with the existing "bsp-specific" defines. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: adi boards: also set stderr to nc with helperMike Frysinger
2011-07-12Blackfin: adi boards: enable pretty flash progress outputMike Frysinger
For only ~150 bytes increase in size, we can get a nice flash progress indicator rather than just the boring dots (which don't tell too much about overall progress). So enable it for all ADI boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: adi boards: enable multi serial support by defaultMike Frysinger
Since this only adds less than 3KiB, enable for all ADI boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-25Blackfin: adi boards: add eon to the "all" spi flash listMike Frysinger
2011-04-25Blackfin: bf537-stamp/bf527-ad7160-eval: convert to mmc_spiMike Frysinger
Switch to the new common mmc_spi driver. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: adi boards: enable CONFIG_MONITOR_IS_IN_RAMMike Frysinger
Our monitor is always in RAM, so enable this define for the CFI layer. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: adi boards: enable ldrinfoMike Frysinger
2011-04-08Blackfin: adi boards: drop old ELF defineMike Frysinger
This define isn't used anywhere anymore, so punt it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-25Blackfin: adi boards: set compiled size limitsMike Frysinger
2010-10-02Blackfin: bf548-ezkit: bump SPI flash size upMike Frysinger
The current size used (256KiB) is smaller than the LDR created for the bf548-ezkit, so 'run update' doesn't work correctly. So bump up the size a bit by making this flexible per-board config. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: adi config: enable nand lock/unlock supportMike Frysinger
We use the lock/unlock options in our default nand code, so enabl support for the options. Reported-by: Vivi Li <vivi.li@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: adi config: allow boards to tweak a little moreMike Frysinger
Let people easily override bootdelay and network settings. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: adi config: add a hook for boards to append the envMike Frysinger
2010-10-02Blackfin: adi config: add an "all spi flashes" option to unify board listsMike Frysinger
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2010-07-25Blackfin: bf533/bf561 boards: convert to new soft gpio i2c codeMike Frysinger
Use the new common gpio framework to simplify and unify the soft i2c configuration settings. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2010-07-13Blackfin: enable IP defrag for ADI boardsMike Frysinger
2010-07-13Blackfin: unify default I2C settings for ADI boardsMike Frysinger
2010-07-13Blackfin: bfin_spi: support gpios as chip selectsMike Frysinger
Rather than only support the pins dedicated as chip selects, utilize the gpio framework to support any gpio pin. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: unify custom gpio commandsMike Frysinger
Now that we have a unified gpio layer, the misc partial gpio commands can be unified and made complete (support all possible gpios). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: add support for kgdbRobin Getz
Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: enable JFFS summary support for ADI boardsMike Frysinger
2010-01-17Blackfin: add a netconsole helperRobin Getz
2010-01-17Blackfin: bf527-ezkit: auto-select NAND settingsMike Frysinger
2010-01-17Blackfin: ADI settings: enable silent console supportMike Frysinger
Very little additional code overhead, and only works when the user sets an env var ahead of time, so default to on makes sense. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
