path: root/include/configs/bf548-ezkit.h
2010-01-17Blackfin: convert bfin_sdh to generic mmcCliff Cai
Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: bf527-ezkit: auto-select NAND settingsMike Frysinger
2010-01-17Blackfin: tweak embedded LDR env config optionMike Frysinger
Use the common config option for extracting the environment for embedding into LDR files and clarify the LDR-specific option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-22Convert SMC911X Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC911X* to CONFIG_SMC911X* - cleaned up line lengths - modified all boards that override weak function in this driver - added Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Mike Frysinger <vapier@gentoo.org>
2009-06-15Blackfin: fix SPI flash speed define nameMike Frysinger
The SPI flash define is named CONFIG_SF_DEFAULT_SPEED, not CONFIG_SF_DEFAULT_HZ, so fix the typos in the Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-15Blackfin: bf548-ezkit: bump up monitor sizeMike Frysinger
The latest version of U-Boot got a bit fatter in the BSS section which caused overflows in the RAM region, so increase the monitor size. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: convert specific pre/post config headers to common methodMike Frysinger
The Blackfin port was using asm/blackfin-config-{pre,post}.h to setup common Blackfin board defines. The common method now is to use config.h, so convert blackfin-config-post.h to that. Rename the still Blackfin specific blackfin-config-pre.h to config-pre.h so the naming conventions at least line up. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-02Blackfin: bf548-ezkit: new board portMike Frysinger
