path: root/include/configs/bf538f-ezkit.h
2014-09-24kconfig: move CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED to KconfigMasahiro Yamada
If this option is enabled, the objects under lib/ directory are compiled with speed optimization, not size optimization. (Currently, only used by some Blackfin boards.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-08-07blackfin: convert blackfin board_f and board_r to use generic board init ↵Sonic Zhang
functions - move blackfin specific cpu init code from blackfin board.c to cpu.c - remove blackfin specific board init code and invoke generic board_f fron cpu init entry - rename section name bss_vma to bss_start in order to match the generic board init code - add a fake relocate_code function to set up the new stack only Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2014-03-07kbuild, blackfin: Add CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEEDMasahiro Yamada
Many (but not all) of Blackfin boards give -O2 option to compile under lib/ directory. That means lib/ should be speed-optimized, whereas other parts should be size-optimized. We want to keep the same behavior, but do not want to parse board/*/config.mk again and again. We've got no choice but to invent a new method. CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED, if it is enabled, gives -O2 flag only for building under lib/ directory. Dirty codes which I had marked as "FIX ME" in board/${BOARD}/config.mk have been deleted. Instead, CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED has been defined in include/configs/${BOARD}.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.zhang@analog.com>
2013-11-17Makefile: rename all libraries to built-in.oMasahiro Yamada
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-19Blackfin: tweak objects specified before embedded environmentMike Frysinger
The partial linking patch changes how objects are specified to the linker and breaks boards with an embedded environment. So we need to tweak the list of objects we specify via the linker script that go in the gap before the embedded env to work with this new behavior. This fixes linker errors for all the boards in question. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: adi config: add an "all spi flashes" option to unify board listsMike Frysinger
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: unify default I2C settings for ADI boardsMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2010-04-13blackfin: Move cpu/blackfin/* to arch/blackfin/cpu/*Peter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-01-17Blackfin: tweak embedded LDR env config optionMike Frysinger
Use the common config option for extracting the environment for embedding into LDR files and clarify the LDR-specific option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-15Blackfin: fix SPI flash speed define nameMike Frysinger
The SPI flash define is named CONFIG_SF_DEFAULT_SPEED, not CONFIG_SF_DEFAULT_HZ, so fix the typos in the Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: unify u-boot linker scriptsMike Frysinger
All the Blackfin linker scripts were duplicated across the board dirs with no difference save from the semi-often used ENV_IS_EMBEDDED option. So unify all of them in the lib_blackfin/ dir and for the few boards that need to embedded the environment directly, add a LDS_BOARD_TEXT define for them to customize via their board config file. This is much simpler than forcing them to duplicate the rest of the linker script. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: convert specific pre/post config headers to common methodMike Frysinger
The Blackfin port was using asm/blackfin-config-{pre,post}.h to setup common Blackfin board defines. The common method now is to use config.h, so convert blackfin-config-post.h to that. Rename the still Blackfin specific blackfin-config-pre.h to config-pre.h so the naming conventions at least line up. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-02Blackfin: bf538f-ezkit: new board portMike Frysinger
