path: root/include/configs/bf537-stamp.h
2011-09-29Blackfin: bf537-stamp/bf548-ezkit: update POST flash block rangeMike Frysinger
Update the define names for the new common code, and improve the range used on the bf548-ezkit. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29Blackfin: post: generalize led/button tests with GPIOsMike Frysinger
Make it easy for any Blackfin board to enable led/push button tests. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29Blackfin: bf537-stamp: convert to gpio post hotkeyMike Frysinger
No need for our custom implementations now that common code supports the generic gpio layer. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: post: setup default CONFIG_SYS_POST_WORD_ADDRMike Frysinger
Set the default post word location to an L1 data location for all Blackfin parts so things "just work" for most people. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-25Blackfin: bf537-stamp/bf527-ad7160-eval: convert to mmc_spiMike Frysinger
Switch to the new common mmc_spi driver. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-19Blackfin: tweak objects specified before embedded environmentMike Frysinger
The partial linking patch changes how objects are specified to the linker and breaks boards with an embedded environment. So we need to tweak the list of objects we specify via the linker script that go in the gap before the embedded env to work with this new behavior. This fixes linker errors for all the boards in question. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: adi config: add an "all spi flashes" option to unify board listsMike Frysinger
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2010-07-14Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2010-07-13Blackfin: unify default I2C settings for ADI boardsMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2010-07-08Blackfin: convert plat-nand code to GPIO frameworkMike Frysinger
Use the new GPIO framework code in both the Blackfin arch and the nand_plat driver to simplify things greatly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: unify custom gpio commandsMike Frysinger
Now that we have a unified gpio layer, the misc partial gpio commands can be unified and made complete (support all possible gpios). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13blackfin: Move cpu/blackfin/* to arch/blackfin/cpu/*Peter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-07Blackfin: bf537-stamp: add board test definesMike Frysinger
We tweak the configs a little when doing automated hardware tests. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: bf537-stamp: rename SPI/MMC defineMike Frysinger
2010-01-17Blackfin: tweak embedded LDR env config optionMike Frysinger
Use the common config option for extracting the environment for embedding into LDR files and clarify the LDR-specific option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-02Blackfin: bf537-stamp: comment CF-Flash Card Support betterMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-07mtd: nand: new base driver for memory mapped nand devicesMike Frysinger
The BF537-STAMP Blackfin board had a driver for working with NAND devices that are simply memory mapped. Since there is nothing Blackfin specific about this, generalize the driver a bit so that everyone can leverage it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-06-15Blackfin: fix SPI flash speed define nameMike Frysinger
The SPI flash define is named CONFIG_SF_DEFAULT_SPEED, not CONFIG_SF_DEFAULT_HZ, so fix the typos in the Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-15Blackfin: bf533-stamp/bf537-stamp: fix env settings for SPI flashVivi Li
The SPI flash layer is much stricter about sector usage than the eeprom layer we used to use, so update the env settings to better match the sector alignment of the flashes we use. Signed-off-by: Vivi Li <vivi.li@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: unify u-boot linker scriptsMike Frysinger
All the Blackfin linker scripts were duplicated across the board dirs with no difference save from the semi-often used ENV_IS_EMBEDDED option. So unify all of them in the lib_blackfin/ dir and for the few boards that need to embedded the environment directly, add a LDS_BOARD_TEXT define for them to customize via their board config file. This is much simpler than forcing them to duplicate the rest of the linker script. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: convert specific pre/post config headers to common methodMike Frysinger
The Blackfin port was using asm/blackfin-config-{pre,post}.h to setup common Blackfin board defines. The common method now is to use config.h, so convert blackfin-config-post.h to that. Rename the still Blackfin specific blackfin-config-pre.h to config-pre.h so the naming conventions at least line up. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-24Blackfin: bf537-stamp: increase monitor sizeMike Frysinger
The new jffs2 code pushed the code size just over the limit, so increase the limit a bit more. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-24Blackfin: bf537-stamp: bump default SCLK up to 125MHzMike Frysinger
Since all of the bf537-stamp and bf537-ezkit boards out there can handle it, increase the speed of SCLK to 125MHz rather than 100MHz. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-24Blackfin: unify common ADI board settingsMike Frysinger
Rather than duplicate the same ADI settings in every ADI board, create a common ADI config header and have all ADI boards start using that. This will also make merging the ~10 boards I have to forward port a lot easier. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-21Blackfin: bf537-stamp: fix I2C board definesMike Frysinger
The previous merge for cleaning up the I2C driver incorrectly reverted the CFG_xxx rename for some of the I2C defines. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Heiko Schocher <hs@denx.de>
2009-01-28Blackfin: overhaul i2c driverMike Frysinger
The current Blackfin i2c driver does not work properly with certain devices due to it breaking up transfers incorrectly. This is a rewrite of the driver and relocates it to the newer place in the source tree. Also remove duplicated I2C speed defines in Blackfin board configs and disable I2C slave address usage since it isn't implemented. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-03-30Blackfin: unify cpu and boot modesMike Frysinger
All of the duplicated code for Blackfin processors and boot modes have been unified. After all, the core is the same for all processors, just the peripheral set differs (which gets handled in the drivers). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: BF537-stamp: drop board-specific flash driver for CFIMike Frysinger
The parallel flash on the BF537-STAMP is CFI compliant, so there is no need for the board specific driver at all. Just use the common CFI driver. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: convert BFIN_CPU to CONFIG_BFIN_CPUMike Frysinger
Stop tying things to the processor that should be tied to other defines and change BFIN_CPU to CONFIG_BFIN_CPU so that it can be used in the build system to select the -mcpu option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-08Clear up confusion over the CMD_POST and POST_DIAG mess.Jon Loeliger
For some reason, CONFIG_POST permeated as CONFIG_CMD_POST_DIAG when it really means just CONFIG_CMD_DIAG. There is no CMD_POST. Clear this mess up some. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-05Minor coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-07-05include/configs: Use new CONFIG_CMD_* in various b* named board config files.Jon Loeliger
2007-03-19[Blackfin][PATCH] Add BF537 stamp board supportAubrey Li
