path: root/include/configs/bf537-srv1.h
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: bf537-minotaur/bf537-srv1: undefine nfs when net is disabledMike Frysinger
Fixes a build error due to new partial linking logic. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: tweak embedded LDR env config optionMike Frysinger
Use the common config option for extracting the environment for embedding into LDR files and clarify the LDR-specific option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-18Blackfin: bf537-{minotaur,srv1}: do not hardcode CONFIG_ETHADDRMike Frysinger
MAC addresses should not be hardcoded in boards to avoid random link level conflicts. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-15Blackfin: fix SPI flash speed define nameMike Frysinger
The SPI flash define is named CONFIG_SF_DEFAULT_SPEED, not CONFIG_SF_DEFAULT_HZ, so fix the typos in the Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: convert specific pre/post config headers to common methodMike Frysinger
The Blackfin port was using asm/blackfin-config-{pre,post}.h to setup common Blackfin board defines. The common method now is to use config.h, so convert blackfin-config-post.h to that. Rename the still Blackfin specific blackfin-config-pre.h to config-pre.h so the naming conventions at least line up. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: bf537-srv1: new board portMike Frysinger
