path: root/include/configs/bf533-stamp.h
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-19Blackfin: tweak objects specified before embedded environmentMike Frysinger
The partial linking patch changes how objects are specified to the linker and breaks boards with an embedded environment. So we need to tweak the list of objects we specify via the linker script that go in the gap before the embedded env to work with this new behavior. This fixes linker errors for all the boards in question. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: adi config: add an "all spi flashes" option to unify board listsMike Frysinger
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-25Blackfin: bf533/bf561 boards: convert to new soft gpio i2c codeMike Frysinger
Use the new common gpio framework to simplify and unify the soft i2c configuration settings. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2010-07-13Blackfin: unify default I2C settings for ADI boardsMike Frysinger
2010-07-05Blackfin: switch to common GPIO LED driverMike Frysinger
Now that we have a unified gpio layer, the different status led implementations can be switched to the common gpio led driver. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: back out status_led.h stubsMike Frysinger
When boards define CONFIG_BOARD_SPECIFIC_LED, the common led definitions are OK for Blackfin boards. So switch the few boards using these over to the common code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13blackfin: Move cpu/blackfin/* to arch/blackfin/cpu/*Peter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-01-17Blackfin: tweak embedded LDR env config optionMike Frysinger
Use the common config option for extracting the environment for embedding into LDR files and clarify the LDR-specific option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-18Blackfin: bf533-stamp: back down SCLK a bitMike Frysinger
While the 1.0 and 1.2 spin of the bf533-stamp boards can handle the higher SCLK speeds just fine, the 1.1 spin cannot due to the bugs introduced with the shortened SDRAM traces. So lower the SCLK speed down to a value that all three can handle. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-15Blackfin: fix SPI flash speed define nameMike Frysinger
The SPI flash define is named CONFIG_SF_DEFAULT_SPEED, not CONFIG_SF_DEFAULT_HZ, so fix the typos in the Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-15Blackfin: bf533-stamp/bf537-stamp: fix env settings for SPI flashVivi Li
The SPI flash layer is much stricter about sector usage than the eeprom layer we used to use, so update the env settings to better match the sector alignment of the flashes we use. Signed-off-by: Vivi Li <vivi.li@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: unify u-boot linker scriptsMike Frysinger
All the Blackfin linker scripts were duplicated across the board dirs with no difference save from the semi-often used ENV_IS_EMBEDDED option. So unify all of them in the lib_blackfin/ dir and for the few boards that need to embedded the environment directly, add a LDS_BOARD_TEXT define for them to customize via their board config file. This is much simpler than forcing them to duplicate the rest of the linker script. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: convert specific pre/post config headers to common methodMike Frysinger
The Blackfin port was using asm/blackfin-config-{pre,post}.h to setup common Blackfin board defines. The common method now is to use config.h, so convert blackfin-config-post.h to that. Rename the still Blackfin specific blackfin-config-pre.h to config-pre.h so the naming conventions at least line up. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-24Blackfin: bf533-stamp: bump up default clocksMike Frysinger
Since the hardware can handle it, bump the default clocks from 80mhz SCLK and 398mhz CCLK to 100mhz SCLK and 498mhz CCLK. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-24Blackfin: bf533-stamp: rewrite startup LED notificationsMike Frysinger
Again, don't clobber pins that we aren't actually using, and use the common LED framework rather than our own hob-job-but-not-really-working. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-24Blackfin: unify common ADI board settingsMike Frysinger
Rather than duplicate the same ADI settings in every ADI board, create a common ADI config header and have all ADI boards start using that. This will also make merging the ~10 boards I have to forward port a lot easier. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-28Blackfin: overhaul i2c driverMike Frysinger
The current Blackfin i2c driver does not work properly with certain devices due to it breaking up transfers incorrectly. This is a rewrite of the driver and relocates it to the newer place in the source tree. Also remove duplicated I2C speed defines in Blackfin board configs and disable I2C slave address usage since it isn't implemented. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-30Blackfin: unify cpu and boot modesMike Frysinger
All of the duplicated code for Blackfin processors and boot modes have been unified. After all, the core is the same for all processors, just the peripheral set differs (which gets handled in the drivers). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-15Blackfin: convert BFIN_CPU to CONFIG_BFIN_CPUMike Frysinger
Stop tying things to the processor that should be tied to other defines and change BFIN_CPU to CONFIG_BFIN_CPU so that it can be used in the build system to select the -mcpu option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various b* named board config files.Jon Loeliger
2007-03-12[Blackfin][PATCH] minor cleanupAubrey Li
2007-03-10[Blackfin][PATCH] code cleanupAubrey Li
2007-03-09[Blackfin]PATCH-1/2]: Remove obsolete blackfin port and add bf533 platform ↵Aubrey.Li
support
