path: root/include/configs/bf525-ucr2.h
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-06blackfin: Add missing macro CONFIG_BFIN_SERIALSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2011-04-08Blackfin: bf525-ucr2: new board portChong Huang
Signed-off-by: Chong Huang <chuang@ucrobotics.com> Signed-off-by: Haitao Zhang <minipanda@linuxrobot.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
