path: root/include/configs/bf518f-ezbrd.h
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: unify default I2C settings for ADI boardsMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2010-07-13Blackfin: bf518f-ezbrd: handle different PHYs dynamicallyMike Frysinger
The original BF518F-EZBRD's have a Micrel KSZ8893 DSA on them, but newer ones only have a National PHY (which lack a RX Error interrupt line). So in the board eth init code, dynamically detect what is hooked up to the MAC and handle each accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: bf518f-ezbrd: increase monitor lengthMike Frysinger
The addition of KGDB overflowed the current linker section. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: convert bfin_sdh to generic mmcCliff Cai
Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: tweak embedded LDR env config optionMike Frysinger
Use the common config option for extracting the environment for embedding into LDR files and clarify the LDR-specific option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-15Blackfin: fix SPI flash speed define nameMike Frysinger
The SPI flash define is named CONFIG_SF_DEFAULT_SPEED, not CONFIG_SF_DEFAULT_HZ, so fix the typos in the Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: bf518f-ezbrd: enable SST SPI flash driverMike Frysinger
The BF51xF parts have an internal SST SPI flash, so make sure the driver is enabled by default so we can access it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: convert specific pre/post config headers to common methodMike Frysinger
The Blackfin port was using asm/blackfin-config-{pre,post}.h to setup common Blackfin board defines. The common method now is to use config.h, so convert blackfin-config-post.h to that. Rename the still Blackfin specific blackfin-config-pre.h to config-pre.h so the naming conventions at least line up. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-05-25Blackfin: bf518f-ezbrd: setup portmux for async flashGraf Yang
The pins for async memory where parallel flash lives are not enabled by default, so make sure we mux them as needed. Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-02Blackfin: bf518f-ezbrd: new board portMike Frysinger
