path: root/include/configs/beaver.h
2015-08-05configs: Remove CONFIG_SERIAL_MULTIStephen Warren
This config option isn't used anywhere at all. Remove all places that define/enable the option. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-03-04ARM: tegra: move common config defines centrallyStephen Warren
All boards need CONFIG_BOARD_EARLY_INIT_F, and many actively need CONFIG_BOARD_LATE_INIT. Move both of these into tegra-common.h so that board config headers don't need to repeatedly define them. Later commits will add new code in board_late_init() which applies to all boards, so CONFIG_BOARD_LATE_INIT should be enabled for all Tegra boards. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-18ARM: tegra: Enable PCIe on BeaverThierry Reding
The Beaver has an ethernet NIC connected to the PCIe bus. Enable the PCIe controller and the network device driver so that the device can boot over the network. In addition the board has a mini-PCIe expansion slot. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-11dm: i2c: tegra: Convert to driver modelSimon Glass
This converts all Tegra boards over to use driver model for I2C. The driver is adjusted to use driver model and the following obsolete CONFIGs are removed: - CONFIG_SYS_I2C_INIT_BOARD - CONFIG_I2C_MULTI_BUS - CONFIG_SYS_MAX_I2C_BUS - CONFIG_SYS_I2C_SPEED - CONFIG_SYS_I2C This has been tested on: - trimslice (no I2C) - beaver - Jetson-TK1 It has not been tested on Tegra 114 as I don't have that board. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-08-18ARM: tegra: enable DFU tooStephen Warren
Enable DFU protocol support (via the "dfu" command) on Tegra boards where USB device/gadget mode is enabled. Note that for DFU to operate correctly on Tegra, we still need some DFU fixes/enhancements that are going through the DFU -> USB trees. However, the code builds just fine without those changes, and applying this patch now will allow both sets of patches to meet in the main U-Boot tree much more quickly. In order to run test/dfu/dfu_gadget_test.sh, you would need to add the following to the board configuration: CONFIG_EXT4_WRITE CONFIG_CMD_EXT4_WRITE However, I haven't enabled those here, since I believe the main use-case for DFU on Tegra is raw flash writing, rather than filesystem access, so we don't need the additional code-size hit. However, I could be persuaded otherwise! We should probably add a separate test script for raw flash access. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-06-05ARM: tegra: enable USB device mode and UMS on some boardsStephen Warren
For each of Jetson TK1, Venice2, and Beaver: - Enable the first USB controller in DT, and describe its configuration. - Enable USB device/gadget support. This allows the user to type e.g. "ums 0 mmc 0" at the command-line to cause U-Boot to act a USB device implementing the USB Mass Storage protocol, and expose MMC device 0 that way. This allows a host PC to mount the Tegra device's MMC, partition it, and install a filesystem on it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-05-13ARM: tegra: use a CPU freq that all SKUs can supportStephen Warren
U-Boot on Tegra30 currently selects a main CPU frequency that cannot be supported at all on some SKUs, and needs higher VDD_CPU/VDD_CORE values on some others. This can result in unreliable operation of the main CPUs. Resolve this by switching to a CPU frequency that can be supported by any SKU. According to the following link, the maximum supported CPU frequency of the slowest Tegra30 SKU is 600MHz: repo http://nv-tegra.nvidia.com/gitweb/?p=linux-2.6.git;a=summary branch l4t/l4t-r16-r2 path arch/arm/mach-tegra/tegra3_dvfs.c table cpu_dvfs_table[] According to that same table, the minimum VDD_CPU required to operate at that frequency across all SKUs is 1.007V. Given the adjustment resolution of the TPS65911 PMIC that's used on all Tegra30-based boards we support, we'll end up using 1.0125V instead. At that VDD_CPU, tegra3_get_core_floor_mv() in that same file dictates that VDD_CORE must be at least 1.2V on all SKUs. According to tegra_core_speedo_mv() (in tegra3_speedo.c in the same source tree), that voltage is safe for all SKUs. An alternative would be to port much of the code from tegra3_dvfs.c and tegra3_speedo.c in the kernel tree mentioned above. That's more work than I want to take on right now. While all the currently supported boards use the same regulator chip for VDD_CPU, different types of regulators are used for VDD_CORE. Hence, we add some small conditional code to select how VDD_CORE is programmed. If this becomes more complex in the future as new boards are added, or we end up adding code to detect the SoC SKU and dynamically determine the allowed frequency and required voltages, we should probably make this a runtime call into a function provided by the board file and/or relevant PMIC driver. Cc: Alban Bedel <alban.bedel@avionic-design.de> Cc: Marcel Ziswiler <marcel@ziswiler.com> Cc: Bard Liao <bardliao@realtek.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23tegra: i2c: Enable new CONFIG_SYS_I2C frameworkSimon Glass
This enables CONFIG_SYS_I2C on Tegra, updating existing boards and the Tegra i2c driver to support this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heiko Schocher <hs@denx.de>
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and serial. Conflicts: arch/arm/dts/exynos5250.dtsi Signed-off-by: Tom Rini <trini@ti.com>
2013-07-11Tegra: Config: Enable Tegra30/Tegra114 USB functionJim Lin
Add USB EHCI, storage and network support. Tested on Tegra30 Cardhu, and Tegra114 Dalmore platforms. All works well. Signed-off-by: Jim Lin <jilin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-06-13ARM: tegra: make use of negative ENV_OFFSET on NVIDIA boardsStephen Warren
Use a negative value of CONFIG_ENV_OFFSET for all NVIDIA reference boards that store the U-Boot environment in the 2nd eMMC boot partition. This makes U-Boot agnostic to the size of the eMMC boot partition, which can vary depending on which eMMC device was actually stuffed into the board. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-04-15Tegra: T30: Beaver board support.Tom Warren
Beaver is a Tegra30 board that is nearly 100% compatible w/Cardhu. Add a Beaver build so it can begin to be differentiated, if need be. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
