path: root/include/configs/bayleybay.h
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-12x86: Convert to use DM VESA video driverBin Meng
At present only chromebook boards are converted to DM video. Other x86 boards are still using the legacy cfb_console driver. This switches to use DM version drivers. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-19x86: Add an i8042 device for boards that have itSimon Glass
Some boards have an i8042 device. Enable the driver for all x86 boards, and add a device tree node for those which may have this keyboard. Also adjust the configuration so that i8042 is always separate from the VGA, and rename the stdin driver accordingly. With this commit the keyboard will not work, but it is fixed in the next commit. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-13x86: Remove CONFIG_SYS_EARLY_PCI_INITBin Meng
CONFIG_SYS_EARLY_PCI_INIT is not needed any more since with driver model, PCI enumeration is automatically triggered. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-26x86: Enable CONFIG_PCI_CONFIG_HOST_BRIDGE for all boardsBin Meng
It looks that x86 chipset always contains a host bridge at pci b.d.f 0.0.0, so enable this for all boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-14x86: baytrail: Add all IDE/SATA PCI device IDsBin Meng
The BayTrail SoC has 4 different PCI devices IDs regarding to IDE and AHCI. Add these IDs in pci_ids.h and also add the other SATA ID in the Bayley Bay and MinnowMax board configuration header. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05x86: Move CONFIG_X86_SERIAL to KconfigSimon Glass
Move this config option to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05x86: bayleybay: Configure PCI IRQBin Meng
Add PCI IRQ routing information in the board device tree and enable writing PIRQ routing table and MP table. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-05x86: Add Intel Bayley Bay board supportBin Meng
Intel Bayley Bay board is a BayTrail based board. Add this board with existing baytrail fsp support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
