path: root/include/configs/axs10x.h
2017-03-24arc: use timer driver for ARC boardsVlad Zakharov
This commit replaces legacy timer code with usage of arc timer driver. It removes arch/arc/lib/time.c file and selects CONFIG_CLK, CONFIG_TIMER and CONFIG_ARC_TIMER options for all ARC boards by default. Therefore we remove CONFIG_CLK option from less common axs101 and axs103 defconfigs. Also it removes legacy CONFIG_SYS_TIMER_RATE config symbol from axs10x.h, tb100.h and nsim.h configs files as it is no longer required. Signed-off-by: Vlad Zakharov <vzakhar@synopsys.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move CONFIG_DWMMC to Kconfig, renaming to CONFIG_MMC_DWMasahiro Yamada
This commit was created as follows: [1] Rename the option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g' [2] create the entry for MMC_DW in drivers/mmc/Kconfig (the prompt and help were copied from Linux) [3] run "tools/moveconfig.py -y MMC_DW" [4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry [5] Clean-up doc/README.socfpga by hand Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-08-05arc: Rename AXS101 board to more generic AXS10xAlexey Brodkin
As of now we have 2 flavors of ARC SDP boards: 1) AXS101 - with ARC770 in ASIC 2) AXS103 - with ARC HS38 in FPGA Both options share exactly the same base-board and only differ with CPU-tiles in use. That means all peripherals are the same (they are implemented in FPGA on the base-board) and so generic board could be used for both. While at it: * Recreated defconfigs with savedefconfig * In include/configs/axs10x.h numerical sizes replaced with defines from linux/sizes.h for better readability. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Reviewed-by: Tom Rini <trini@konsulko.com>
