path: root/include/configs/atstk1002.h
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-06-15avr32: move CONFIG_SYS_GENERIC_BOARD to KconfigMasahiro Yamada
Now all the AVR32 boards have been converted into Generic Board. Select it in Kconfig and clean up defines in header files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-02-17atstk1002: enable generic boardAndreas Bießmann
2015-02-17avr32: use dlmalloc for DMA buffersAndreas Bießmann
2014-01-24avr32: move CONFIG_AVR32 definition to arch/avr32/config.mkMasahiro Yamada
Like other architectures, CONFIG_AVR32 can be defined in arch/avr32/config.mk rather than board header files. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-11-02avr32: allow multi block mmc access for all boardsAndreas Bießmann
Commit 1db7377a70a8d931c32648e717695133120d5456 fixes the gen_atmel_mci driver to be able to use multi block access for avr32. Therefore remove the setting which forces single block access. This also adds a huge performace gain for mmc access: ---8<--- Loading file "/boot/uImage" from mmc device 0:1 1830666 bytes read in 1293 ms (1.3 MiB/s) --->8--- vs. ---8<--- Loading file "/boot/uImage" from mmc device 0:1 1830666 bytes read in 237 ms (7.4 MiB/s) --->8--- Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: haavard.skinnemoen@atmel.com Cc: hans-christian.egtvedt@atmel.com Cc: mpfj@mimc.co.uk Cc: alex.raimondi@miromico.ch Cc: julien.may@miromico.ch Cc: egtvedt@samfundet.no Cc: havard@skinnemoen.net
2012-03-13ATMEL: use generic mmc frameworkSven Schnelle
gen_atmel_mci works on AVR32 as well, so no need to use the legacy mmc driver. This also has the nice side effect of being able to use SDHC cards an those boards. Signed-off-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2011-07-04atstk100x: switch to common cfi driverAndreas Bießmann
This patch removes the board implemenatation for flash driver which can now safely switched to the common cfi driver. Compile tested for all atstk100x boards, runtime tested on atstk1002. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18atstk100x: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
2011-05-18atstk1002: fix "#define XXXX 1"Andreas Bießmann
2011-05-18avr32: fixup definitions to ATMEL_BASE_xxxAndreas Bießmann
2011-05-18avr32: rename memory-map.h -> hardware.hAndreas Bießmann
2010-09-03avr32: Add simple paging supportHaavard Skinnemoen
Use the MMU hardware to set up 1:1 mappings between physical and virtual addresses. This allows us to bypass the cache when accessing the flash without having to do any physical-to-virtual address mapping in the CFI driver. The virtual memory mappings are defined at compile time through a sorted array of virtual memory range objects. When a TLB miss exception happens, the exception handler does a binary search through the array until it finds a matching entry and loads it into the TLB. The u-boot image itself is covered by a fixed TLB entry which is never replaced. This makes the 'saveenv' command work again on ATNGW100 and other boards using the CFI driver, hopefully without breaking any rules. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-17Merge branch 'fixes' into cleanupsHaavard Skinnemoen
Conflicts: board/atmel/atngw100/atngw100.c board/atmel/atstk1000/atstk1000.c cpu/at32ap/at32ap700x/gpio.c include/asm-avr32/arch-at32ap700x/clk.h include/configs/atngw100.h include/configs/atstk1002.h include/configs/atstk1003.h include/configs/atstk1004.h include/configs/atstk1006.h include/configs/favr-32-ezkit.h include/configs/hammerhead.h include/configs/mimc200.h
2008-09-01avr32: refactor the portmux/gpio codeHaavard Skinnemoen
- Separate the portmux configuration functionality from the GPIO pin control API. - Separate the controller-specific code from the chip-specific code. - Allow "ganged" port configuration (multiple pins at once). - Add more flexibility to the "canned" peripheral select functions: - Allow using more than 23 address bits, more chip selects, as well as NAND- and CF-specific pins. - Make the MACB SPEED pin optional, and choose between MII/RMII using a parameter instead of an #ifdef. - Make it possible to use other MMC slots than slot 0, and support different MMC/SDCard data bus widths. - Use more reasonable pull-up defaults; floating pins may consume a lot of power. - Get rid of some custom portmux code from the mimc200 board code. The old gpio/portmux API couldn't really handle its requirements, but the new one can. - Add documentation. The end result is slightly smaller code for all boards. Which isn't really the point, but at least it isn't any larger. This has been verified on ATSTK1002 and ATNGW100. I'd appreciate if the board maintainers could help me test this on their boards. In particular, the mimc200 port has lost a lot of code, so I'm hoping Mark can help me out. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Mark Jackson <mpfj@mimc.co.uk> Cc: Alex Raimondi <alex.raimondi@miromico.ch> Cc: Julien May <julien.may@miromico.ch> Changes since v1: * Enable pullup on NWAIT * Add missing include to portmux-pio.h * Rename CONFIG_PIO2 -> CONFIG_PORTMUX_PIO to match docs
2008-07-31Fix printf() format problems with configurable promptsWolfgang Denk
U-Boot allows for configurable prompt strings using the CONFIG_AUTOBOOT_PROMPT resp. CONFIG_MENUPROMPT definitions. So far, the assumption was that any such user defined problts would contain exactly one "%d" format specifier. But some boards did not. To allow for flexible boot prompts without adding too complex code we now allow to specify the whole list of printf() arguments in the user definition. This is powerful, but requires a responsible user who really understands what he is doing, as he needs to know for exanple which variables are available in the respective context. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-07-10avr32: Use CONFIG_ATMEL_MCI to select the atmel_mci driverHaavard Skinnemoen
After we move the atmel_mci driver into drivers/mmc, we can't select it with CONFIG_MMC anymore. Introduce a new symbol specifically for this driver so that there's no ambiguity. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Jean-Chritophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-27avr32: Rework SDRAM initialization codeHaavard Skinnemoen
This cleans up the SDRAM initialization and related code a bit, and allows faster booting. * Add definitions for EBI and internal SRAM to asm/arch/memory-map.h * Remove memory test from sdram_init() and make caller responsible for verifying the SDRAM and determining its size. * Remove base_address member from struct sdram_config (was sdram_info) * Add data_bits member to struct sdram_config and kill CFG_SDRAM_16BIT * Add support for a common STK1000 hack: 16MB SDRAM instead of 8. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-27avr32: stk1002 and ngw100 convergenceDavid Brownell
Make STK1002 and NGW100 boards act more alike: - STK boards can use as many arguments as NGW - STK boards don't need to manage FPGAs either - NGW commands should match STK ones Also spell U-Boot right in prompts for STK1002 and NGW100. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> [haavard.skinnemoen@atmel.com: update STK100[34] as well] Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-02-05ATSTK1002: Use SDRAM + 4MB as default load addressHaavard Skinnemoen
Many people run into problems when they compile a big kernel and load the uImage at the default SDRAM + 2MB address as the kernel will overwrite the uImage as it is being unpacked. Increase the default load address so that we can load a 4MB kernel image without any problems. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-11-01ATSTK1002: Remove default ethernet addressesHaavard Skinnemoen
Wolfgang is right: It's not a good idea to set up default initial ethernet addresses for a board, even though they belong to the local range. This will change the failure mode from "IT manager screams at you for using duplicate ethernet addresses" to a nice error message explaining that the ethernet address hasn't been set properly. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-10-02Fix memtest breakageHaavard Skinnemoen
CFG_MEMTEST_START uses weird magic involving gd, which fails to compile. Use hardcoded values instead (we actually know how much RAM we have on board.) Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-10-02Merge commit 'origin/master'Haavard Skinnemoen
2007-09-18Update atstk1002 bootargs.Eirik Aanonsen
Updates to atstk1002 U-Boot header file: - Changed bootargs: * Set the bootargs for at1002 to point to the SD-card partition instead * ... of the boot flash. * Removing the rootfstype since that argument are not needed. Signed-off-by: Eirik Aanonsen <eaa@wprmedical.com> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-09-18Add some comments to clocks in atstk1002.hEirik Aanonsen
This patch applies some clarifying comments to how the different clocks are setup according to atstk1002.h Some of the previous comments where stating wrongful information. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-08-30Reduce BOOTDELAY variable to 1 second by default for STK1002Hans-Christian Egtvedt
Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-08-30Remove double quotation marks around MAC address for STK1002Hans-Christian Egtvedt
2007-07-09include/configs/[a-m]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05Minor coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-07-05include/configs: Use new CONFIG_CMD_* in various a* named board config files.Jon Loeliger
2007-04-18Merge with /home/wd/git/u-boot/custodian/u-boot-avr32; code cleanup.Wolfgang Denk
2007-04-14AVR32: Enable MMC supportHaavard Skinnemoen
Set up the portmux for the MMC interface and enable the MMC driver along with support for DOS partitions, ext2 and FAT filesystems. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Enable networkingHaavard Skinnemoen
Implement MACB initialization for AVR32 and ATSTK1000, and turn everything on, including the MACB driver. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Include more commands for ATSTK1000Haavard Skinnemoen
Include the imi, imls and jffs commands sets by default on ATSTK1000. Also define CONFIG_BOOTARGS to something more useful, define CONFIG_BOOTCOMMAND and enable autoboot by default. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Relocate u-boot to SDRAMHaavard Skinnemoen
Relocate the u-boot image into SDRAM like everyone else does. This means that we can handle much larger .data and .bss than we used to. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
