path: root/include/configs/atngw100.h
2011-05-18atngw100: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18atngw100: fix "#define XXXX 1"Andreas Bießmann
2011-05-18avr32: fixup definitions to ATMEL_BASE_xxxAndreas Bießmann
2011-05-18avr32: rename memory-map.h -> hardware.hAndreas Bießmann
2010-11-28Remove duplicate #defines in atngw100.h and mimc200.hSemih Hazar
Two configuration include files had duplicate CONFIG_DOS_PARTITION definitions with the same value. This patch does not effect anything, just trims unnecessary text. Signed-off-by: Semih Hazar <semih.hazar@indefia.com>
2010-09-03avr32: Add simple paging supportHaavard Skinnemoen
Use the MMU hardware to set up 1:1 mappings between physical and virtual addresses. This allows us to bypass the cache when accessing the flash without having to do any physical-to-virtual address mapping in the CFI driver. The virtual memory mappings are defined at compile time through a sorted array of virtual memory range objects. When a TLB miss exception happens, the exception handler does a binary search through the array until it finds a matching entry and loads it into the TLB. The u-boot image itself is covered by a fixed TLB entry which is never replaced. This makes the 'saveenv' command work again on ATNGW100 and other boards using the CFI driver, hopefully without breaking any rules. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-17Merge branch 'fixes' into cleanupsHaavard Skinnemoen
Conflicts: board/atmel/atngw100/atngw100.c board/atmel/atstk1000/atstk1000.c cpu/at32ap/at32ap700x/gpio.c include/asm-avr32/arch-at32ap700x/clk.h include/configs/atngw100.h include/configs/atstk1002.h include/configs/atstk1003.h include/configs/atstk1004.h include/configs/atstk1006.h include/configs/favr-32-ezkit.h include/configs/hammerhead.h include/configs/mimc200.h
2008-09-01avr32: refactor the portmux/gpio codeHaavard Skinnemoen
- Separate the portmux configuration functionality from the GPIO pin control API. - Separate the controller-specific code from the chip-specific code. - Allow "ganged" port configuration (multiple pins at once). - Add more flexibility to the "canned" peripheral select functions: - Allow using more than 23 address bits, more chip selects, as well as NAND- and CF-specific pins. - Make the MACB SPEED pin optional, and choose between MII/RMII using a parameter instead of an #ifdef. - Make it possible to use other MMC slots than slot 0, and support different MMC/SDCard data bus widths. - Use more reasonable pull-up defaults; floating pins may consume a lot of power. - Get rid of some custom portmux code from the mimc200 board code. The old gpio/portmux API couldn't really handle its requirements, but the new one can. - Add documentation. The end result is slightly smaller code for all boards. Which isn't really the point, but at least it isn't any larger. This has been verified on ATSTK1002 and ATNGW100. I'd appreciate if the board maintainers could help me test this on their boards. In particular, the mimc200 port has lost a lot of code, so I'm hoping Mark can help me out. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Mark Jackson <mpfj@mimc.co.uk> Cc: Alex Raimondi <alex.raimondi@miromico.ch> Cc: Julien May <julien.may@miromico.ch> Changes since v1: * Enable pullup on NWAIT * Add missing include to portmux-pio.h * Rename CONFIG_PIO2 -> CONFIG_PORTMUX_PIO to match docs
2008-07-31Fix printf() format problems with configurable promptsWolfgang Denk
U-Boot allows for configurable prompt strings using the CONFIG_AUTOBOOT_PROMPT resp. CONFIG_MENUPROMPT definitions. So far, the assumption was that any such user defined problts would contain exactly one "%d" format specifier. But some boards did not. To allow for flexible boot prompts without adding too complex code we now allow to specify the whole list of printf() arguments in the user definition. This is powerful, but requires a responsible user who really understands what he is doing, as he needs to know for exanple which variables are available in the respective context. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-07-10avr32: Use CONFIG_ATMEL_MCI to select the atmel_mci driverHaavard Skinnemoen
After we move the atmel_mci driver into drivers/mmc, we can't select it with CONFIG_MMC anymore. Introduce a new symbol specifically for this driver so that there's no ambiguity. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Jean-Chritophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-06-20avr32: Enable SPI flash support on ATNGW100Haavard Skinnemoen
The ATNGW100 has 8MB DataFlash on board. Give users access to it through the new SPI flash framework. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-27avr32: Rework SDRAM initialization codeHaavard Skinnemoen
This cleans up the SDRAM initialization and related code a bit, and allows faster booting. * Add definitions for EBI and internal SRAM to asm/arch/memory-map.h * Remove memory test from sdram_init() and make caller responsible for verifying the SDRAM and determining its size. * Remove base_address member from struct sdram_config (was sdram_info) * Add data_bits member to struct sdram_config and kill CFG_SDRAM_16BIT * Add support for a common STK1000 hack: 16MB SDRAM instead of 8. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-27avr32: stk1002 and ngw100 convergenceDavid Brownell
Make STK1002 and NGW100 boards act more alike: - STK boards can use as many arguments as NGW - STK boards don't need to manage FPGAs either - NGW commands should match STK ones Also spell U-Boot right in prompts for STK1002 and NGW100. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> [haavard.skinnemoen@atmel.com: update STK100[34] as well] Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-02-05ATNGW100: Fix default mtest rangeHaavard Skinnemoen
Let mtest cover the whole SDRAM except the last megabyte, which is where u-boot lives. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-23Coding Style Cleanup; update CHANGELOGWolfgang Denk
2008-01-18AVR32: ATNGW100 board supportHaavard Skinnemoen
Add support for the ATNGW100 Network Gateway reference design, including flash, ethernet and MMC support. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
