path: root/include/configs/atc.h
2003-05-22* Patch by Dave Ellis, 22 May 2003:LABEL_2003_05_23_0055wdenk
Fix problem with only partially cleared .bss segment * Patch by Rune Torgersen, 12 May 2003: get PCI to work on a MPC8266ADS board; incorporate change to cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
2003-05-18Add support for CompactFlash on ATC boardwdenk
(includes support for Intel 82365 and compatible PC Card controllers, and Yenta-compatible PCI-to-CardBus controllers)
2003-05-12Fix SDRAM initializationwdenk
2003-05-05Fix ATC board configuration and flash driverwdenk
2003-05-03* Add support for Promess ATC boardLABEL_2003_05_03_1700wdenk
* Patch by Keith Outwater, 28 Apr 2003: - Miscellaneous corrections and additions to GEN860T board specific code. - Added GEN860_SC variant to GEN860T. - Miscellaneous corrections to GEN860T documentation. - Correct duplicate entry in U-Boot CREDITS file. - Add GEN860T_SC entry in MAINTAINERS file. - Update CREDITS file with GEN860T_SC info. * Update Smiths Aerospace addresses in MAINTAINERS file * Fix error handling in hush's version of "run" command
