path: root/include/configs/atc.h
2014-03-07powerpc: mpc8260: consolidate CONFIG_MPC8260 and CONFIG_8260Masahiro Yamada
Before this commit, CONFIG_MPC8260 and CONFIG_8260 were used mixed-up. All boards with mpc8260 cpu defined both of them: - CONFIG_MPC8260 was defined in board config headers and include/common.h - CONFIG_8260 was defined arch/powerpc/cpu/mpc8260/config.mk We do not need to have both of them. This commit keeps only CONFIG_MPC8260. This commit does: - Delete CONFIG_8260 and CONFIG_MPC8260 definition in config headers and include/common.h - Rename CONFIG_8260 to CONFIG_MPC8260 in arch/powerpc/cpu/mpc8260/config.mk. - Rename #ifdef CONFIG_8260 to #ifdef CONFIG_MPC8260 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2012-10-17split mpc8xx hooks from cmd_ide.cPavel Herrmann
move most of mpc8xx hooks from cmd_ide.c into ide_preinit() and newly created ide_init_postreset() (invoked after calling ide_reset after ide_preinit), some cleanup to make checkpatch happy, enable IDE init hooks in configs of affected boards. confusingly, these hooks are used by more than just mpc8xx-based boards, and therefore are placed in arch/ppc/lib/ note: checkpatch still emits warnings about using volatile Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-07-09include/configs/[a-m]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-09include/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
Mostly removed from comments here. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-05include/configs: Use new CONFIG_CMD_* in various a* named board config files.Jon Loeliger
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2003-06-22Had to move the RTC area for ATC board to upper addressesLABEL_2003_06_22_1530wdenk
(0xf5000000, to be specific). The reason is that the RTC first gets accessed before MMU is initialized and, consequently, it needs to be placed at physical addresses which are later mapped to the same virtual addresses (like 0xf5000000 physical is mapped to 0xf5000000 virtual).
2003-06-18Add support for DS12887 RTC; add RTC support for ATC boardwdenk
2003-05-22* Patch by Dave Ellis, 22 May 2003:LABEL_2003_05_23_0055wdenk
Fix problem with only partially cleared .bss segment * Patch by Rune Torgersen, 12 May 2003: get PCI to work on a MPC8266ADS board; incorporate change to cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
2003-05-18Add support for CompactFlash on ATC boardwdenk
(includes support for Intel 82365 and compatible PC Card controllers, and Yenta-compatible PCI-to-CardBus controllers)
2003-05-12Fix SDRAM initializationwdenk
2003-05-05Fix ATC board configuration and flash driverwdenk
2003-05-03* Add support for Promess ATC boardLABEL_2003_05_03_1700wdenk
* Patch by Keith Outwater, 28 Apr 2003: - Miscellaneous corrections and additions to GEN860T board specific code. - Added GEN860_SC variant to GEN860T. - Miscellaneous corrections to GEN860T documentation. - Correct duplicate entry in U-Boot CREDITS file. - Add GEN860T_SC entry in MAINTAINERS file. - Update CREDITS file with GEN860T_SC info. * Update Smiths Aerospace addresses in MAINTAINERS file * Fix error handling in hush's version of "run" command
