path: root/include/configs/at91sam9x5ek.h
2015-09-11ARM: atmel: boards: use default CONFIG_SYS_PBSIZEBo Shen
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-08-21arm: at91: mpddr: allow multiple DDR controllersErik van Luijk
The mpddr.c depends on ATMEL_BASE_MPDDRC for the base address to configure the controller. This cannot be used when there is more than one controller (i.e. AT91SAM9G45, AT91SAM9M10). Signed-off-by: Erik van Luijk <evanluijk@interact.nl> [remove 'new blank line at EOF'] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-04-01ARM: atmel: at91sam9x5ek: enable spl supportBo Shen
Enable SPL support for at91sam9x5ek board. Now, it supports boot up from NAND flash and SPI flash. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-02-07ARM: at91: at91sam9x5: save environment to a FAT file in MMC cardWu, Josh
This patch will save U-Boot environment as a file: uboot.env, in FAT partition instead of saving it in raw sector of MMC card. This make us easier to manage the environment file. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com>
2014-05-27at91: remove redundant AT91FAMILY definition in board config fileWu, Josh
Now the AT91FAMILY is already defined in the at91 SoC header. The at91 board config file will include the SoC header file. So we can remove the redundant AT91FAMILY definition in at91 board config files. Signed-off-by: Josh Wu <josh.wu@atmel.com> [rebase patch] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-05-27ARM: atmel: at91sam9x5ek: convert to generic boardBo Shen
Enable CONFIG_SYS_GENERIC_BOARD, so that we get rid of the following warning on boot: "Warning: Your board does not use generic board. Please read doc/README.generic-board and take action. Boards not upgraded by the late 2014 may break or be removed." Signed-off-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-17arm: atmel: at91sam9x5: move CONFIG_SYS_NO_FLASH to proper positionBo Shen
In config_cmd_default.h, it will use CONFIG_SYS_NO_FLASH to decide whether include CONFIG_CMD_FLASH and CONFIG_CMD_IMLS. So, move the CONFIG_SYS_NO_FLASH to proper position, then we don't need to undef these two commands. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-17arm: atmel: at91sam9x5: cleanup unneeded undefBo Shen
remove unneeded #undef for at91sam9x5ek board. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-04arm: atmel: get rid of too many ifdefferyBo Shen
Get rid of too many ifdeffery in usb ohci driver Add following two configuration for USB clock selecting - CONFIG_USB_ATMEL_CLK_SEL_PLLB: using PLLB as usb ohci input clock - CONFIG_USB_ATMEL_CLK_SEL_UPLL: using UPLL as usb ohci input clock Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-08-22arm: atmel: remove the config.mk fileBo Shen
remove the config.mk file move text base define to board config file for following boards - at91sam9m10g45ek - at91sam9x5ek Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-08-22ARM: at91: atmel_nand: pmecc driver will select the galois table by sector sizeWu, Josh
Define the galois index table offset in chip head file. So user do not need to set by himself. Driver will set it correctly according to sector_size. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Scott Wood <scottwood@freescale.com> [rebased on master] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-08-22arm: atmel: add nand trimffs subcommand for at91sam9n12 and at91sam9x5Bo Shen
as the at91sam9n12 and at91sam9x5 soc support PMECC, when use u-boot to flash the rootfs, in order to avoid flash one sector with all 0xff into NAND, so use nand trimffs subcommand to avoid it Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-03-12ARM: at91: change nand flash tableBo Shen
Change nand flash partition table according to www.at91.com/linux4sam more information: http://www.at91.com/linux4sam/bin/view/Linux4SAM/GettingStarted#Linux4SAM_NandFlash_demo_Memory Signed-off-by: Bo Shen <voice.shen@atmel.com> [minor commit message changes] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-03-12arm: at91/configs: add bootz to configurationNicolas Ferre
Support to boot zImage Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> [Add bootz for at91rm9200, at91sam9263, at91sam9rl] Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-01-12arm: at91sam9x5: add dataflash boot supportBo Shen
Add dataflash boot support on at91sam9x5ek board Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-01-09Merge 'u-boot-atmel/master' into 'u-boot-arm/master'Albert ARIBAUD
2012-12-09at91sam9x5ek: add USB configurationRichard Genoud
Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Acked-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-12-09at91sam9x5ek: regroup FAT/DOS featuresRichard Genoud
2012-11-27mmc: at91sam9x5: support to save environment in mmcWu, Josh
Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-17ARM: at91sam9x5: enable MCI0 support for 9x5ek board.Wu, Josh
Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-17Atmel: sam9g10/9m10/9x5: Add support to boot DT kernelBo Shen
The mainline linux kernel is moving to flatten device tree support Add the CONFIG_OF_LIBFDT option to support booting DT linux kernel Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01at91: 9x5: Enable PMECC for 5series ek board.Wu, Josh
2012-09-01atmel: at91sam9x5: add spi flash boot supportBo Shen
Add at91sam9x5 series spi flash boot support Using at91sam9x5ek_spiflash to configure, then it can boot from at25df321 serial flash SPI mater work in 30Mhz speed, while not 1Mhz speed. This will base on atmel_spi patch, or else, it will occur receive overrun Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01ARM : at91sam9x5 : Remove CONFIG_ARCH_CPU_INITBo Shen
Remove CONFIG_ARCH_CPU_INIT, no need it anymore Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01arm : Atmel : add at91sam9x5ek board supportBo Shen
Add at91sam9x5ek board support, this board support the following SoCs AT91SAM9G15, AT91SAM9G25, AT91SAM9G35, AT91SAM9X25, AT91SAM9X35 Using at91sam9x5ek_nandflash to configure for the board Now only supports NAND with software ECC boot up Signed-off-by: Bo Shen <voice.shen@atmel.com> [move MAINTAINERS entry to right place] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
