path: root/include/configs/at91sam9x5ek.h
2012-09-01at91: 9x5: Enable PMECC for 5series ek board.Wu, Josh
Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01atmel: at91sam9x5: add spi flash boot supportBo Shen
Add at91sam9x5 series spi flash boot support Using at91sam9x5ek_spiflash to configure, then it can boot from at25df321 serial flash SPI mater work in 30Mhz speed, while not 1Mhz speed. This will base on atmel_spi patch, or else, it will occur receive overrun Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01ARM : at91sam9x5 : Remove CONFIG_ARCH_CPU_INITBo Shen
Remove CONFIG_ARCH_CPU_INIT, no need it anymore Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01arm : Atmel : add at91sam9x5ek board supportBo Shen
Add at91sam9x5ek board support, this board support the following SoCs AT91SAM9G15, AT91SAM9G25, AT91SAM9G35, AT91SAM9X25, AT91SAM9X35 Using at91sam9x5ek_nandflash to configure for the board Now only supports NAND with software ECC boot up Signed-off-by: Bo Shen <voice.shen@atmel.com> [move MAINTAINERS entry to right place] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
