path: root/include/configs/at91sam9rlek.h
2010-03-07ARM change name of defines for AT91 arm926ejsAchim Ehrlich
Configuration defines should be preceeded with CONFIG_SYS_. Renamed some at91 specific defines to conform to this naming convention: AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
2010-02-12add a new AT91 GPIO driverJens Scharsig
* add a real AT91 GPIO driver instead of header inline code * resolve the mixing of port and pins * change board config files to use new driver * add macros to gpio to realize backward compatibility Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-02-12add new CONFIG_AT91_LEGACYJens Scharsig
* add's the new temporary CONFIG_AT91_LEGACY to all board configs This will need for backward compatiblity, while change the SoC access to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated SoC is used. Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-08-18Update the mtd driver name in bootargs for at91-based boardsAlbin Tonnerre
The name of the atmel nand driver in the kernel changed from at91_nand to atmel_nand back in June 2008, but the at91-based boards config files still refer to at91_nand. This patch updates them with the new name Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
2009-07-22AT91: factor out ROUND() macroWolfgang Denk
A large number of boards (all AT91 based) duplicated the ROUND() macro in their board specific config files. Add the definition to include/common.h and clean up the board config files. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18NAND: Part 2: Fix warning Please define CONFIG_SYS_64BIT_VSPRINTF...Wolfgang Denk
Commit 8d2effea added a warning for configurations that use NAND without defining the (then necessary) CONFIG_SYS_64BIT_VSPRINTF but failed to fix the affected boards. This patch covers the non-PPC boards that were missed in the previous patch (commit 170c1972). Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12at91: move cpu name define to arm/arch/ cpu headerJean-Christophe PLAGNIOL-VILLARD
2009-04-16at91sam9/at91cap: fix CONFIG_SYS_HZ to 1000Jean-Christophe PLAGNIOL-VILLARD
The timer has been rewrote with a precision at ~0,18% Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Tested-by: Sergey Lapin <slapin@ossfans.org> Tested-by: Eric BENARD <ebenard@free.fr>
2009-04-16at91sam9/at91cap: improve clock frameworkJean-Christophe PLAGNIOL-VILLARD
calculate dynamically the clock rate and pllb setting for usb Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04at91: move dataflash spi driver to drivers/spiJean-Christophe PLAGNIOL-VILLARD
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-22at91sam9/at91cap: move nand drivers to drivers/mtd/nandJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common led management to cpuJean-Christophe PLAGNIOL-VILLARD
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-12-06at91: Choose environment variables location within make config targetNicolas Ferre
This patch adds the possiblity to choose the media where the environment will be located. This allow to choose this fundamental configuration without editing config files. Documentation file added. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Stelian Pop <stelian@popies.net> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-11-21AT91: Use AT91_CPU_CLOCK in displaysStelian Pop
Introduce AT91_CPU_CLOCK and use it for displaying the CPU speed in the LCD driver. Also make AT91_MAIN_CLOCK and AT91_MASTER_CLOCK reflect the corresponding board clocks. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-09-10rename CFG_ENV_IS_IN_NAND in CONFIG_ENV_IS_IN_NANDJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_DATAFLASH in CONFIG_ENV_IS_IN_DATAFLASHJean-Christophe PLAGNIOL-VILLARD
2008-05-10AT91: Cleanup unused config header file definitions.Stelian Pop
CONFIG_ENV_OVERWRITE is commented out in the config header files, so let's cleanup the files by removing the whole definition. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9RLEK: hook up the ATMEL LCD driverStelian Pop
This patch makes the necessary adaptations (PIO configurations and defines in config header file) to hook up the Atmel LCD driver to the AT91SAM9RLEK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9RLEK supportStelian Pop
This patch adds support for the AT91SAM9RL chip and the AT91SAM9RLEK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
