path: root/include/configs/at91sam9m10g45ek.h
2014-07-07env_fat: use get_device_and_partition() during env save and loadWu, Josh
Use get_device_and_partition() is better since: 1. It will call the device initialize function internally. So we can remove the mmc intialization code to save many lines. 2. It is used by fatls/fatload/fatwrite. So saveenv & load env should use it too. 3. It can parse the "D:P", "D", "D:", "D:auto" string to get correct device and partition information by run-time. Also we remove the FAT_ENV_DEVICE and FAT_ENV_PART. We use a string: FAT_ENV_DEVICE_AND_PART. For at91sam9m10g45ek, it is "0". That means use device 0 and if: a)device 0 has no partition table, use the whole device as a FAT file system. b)device 0 has partittion table, use the partition #1. Refer to the commit: 10a37fd7a4 for details of device & partition string. Signed-off-by: Josh Wu <josh.wu@atmel.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2014-05-27ARM: at91sam9m10g45ek: add mmc environment configuration supportWu, Josh
In this configuration the environment will save in file: uboot.env of mmc card. Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-05-27ARM: at91sam9m10g45ek: enable mci0 supportWu, Josh
Also we enable the mmc command in configuration file. As both CONFIG_CMD_MMC and CONFIG_CMD_USB use the CONFIG_DOS_PARTITION, so remove the redundant CONFIG_DOS_PARTITION definition. Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-05-27at91: remove redundant AT91FAMILY definition in board config fileWu, Josh
Now the AT91FAMILY is already defined in the at91 SoC header. The at91 board config file will include the SoC header file. So we can remove the redundant AT91FAMILY definition in at91 board config files. Signed-off-by: Josh Wu <josh.wu@atmel.com> [rebase patch] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-05-27ARM: atmel: at91sam9m10g45ek: convert to generic boardBo Shen
Enable CONFIG_SYS_GENERIC_BOARD, so that we get rid of the following warning on boot: "Warning: Your board does not use generic board. Please read doc/README.generic-board and take action. Boards not upgraded by the late 2014 may break or be removed." Signed-off-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-01arm: atmel: sam9m10g45ek: let CONFIG_SYS_NO_FLASH at proper positionBo Shen
In config_cmd_default.h, it will use CONFIG_SYS_NO_FLASH to decide whether include CONFIG_CMD_FLASH and CONFIG_CMD_IMLS. So, if the CONFIG_SYS_NO_FLASH defined later than include/config_cmd_default.h, These two commands will be included always. So move CONFIG_SYS_NO_FLASH definition to proper position. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-01arm926ejs, at91: add common phy_reset functionHeiko Schocher
add common phy reset code into a common function. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Jens Scharsig <esw@bus-elektronik.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Stelian Pop <stelian@popies.net> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Eric Benard <eric@eukrea.com> Cc: Markus Hubig <mhubig@imko.de> Acked-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Bo Shen <voice.shen@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-13at91sam9m10g45ek: remove unused CONFIG_AT91_LEGACYAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Bo Shen <voice.shen@atmel.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-08-22arm: atmel: remove the config.mk fileBo Shen
remove the config.mk file move text base define to board config file for following boards - at91sam9m10g45ek - at91sam9x5ek Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-03-12ARM: at91: change nand flash tableBo Shen
Change nand flash partition table according to www.at91.com/linux4sam more information: http://www.at91.com/linux4sam/bin/view/Linux4SAM/GettingStarted#Linux4SAM_NandFlash_demo_Memory Signed-off-by: Bo Shen <voice.shen@atmel.com> [minor commit message changes] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-03-12arm: at91/configs: add bootz to configurationNicolas Ferre
Support to boot zImage Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> [Add bootz for at91rm9200, at91sam9263, at91sam9rl] Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-17Atmel: sam9g10/9m10/9x5: Add support to boot DT kernelBo Shen
The mainline linux kernel is moving to flatten device tree support Add the CONFIG_OF_LIBFDT option to support booting DT linux kernel Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01arm: sam9g10/sam9m10g45: remove CONFIG_ARCH_CPU_INITBo Shen
Remove CONFIG_ARCH_CPU_INIT for at91sam9g10ek and at91sam9m10g45ek Signed-off-by: Bo Shen <voice.shen@atmel.com> [rebase on TOT] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-07-07AT91: at91sam9m10g45ek : Enable EHCI instead OHCIBo Shen
Enable EHCI support instead OHCI Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-04-19CMD: Remove CMD_AUTOSCRIPT, it's not usedMarek Vasut
$ git grep AUTOSCRIPT include/configs/at91sam9m10g45ek.h:#undef CONFIG_CMD_AUTOSCRIPT include/configs/gplugd.h:#define CONFIG_CMD_AUTOSCRIPT Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2012-01-26NAND: Remove additional (CONFIG_SYS)_NAND_MAX_CHIPSScott Wood
NAND_MAX_CHIPS has been replaced by CONFIG_SYS_NAND_MAX_CHIPS, and the latter defaults to 1. Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-11-29Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-09-03atmel: Update support of board AT91SAM9M10G45-EK to new styleThomas Petazzoni
Based on earlier work by Alex Waterman <awaterman@dawning.com>. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-03-07ARM change name of defines for AT91 arm926ejsAchim Ehrlich
Configuration defines should be preceeded with CONFIG_SYS_. Renamed some at91 specific defines to conform to this naming convention: AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
2010-02-12add a new AT91 GPIO driverJens Scharsig
* add a real AT91 GPIO driver instead of header inline code * resolve the mixing of port and pins * change board config files to use new driver * add macros to gpio to realize backward compatibility Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-02-12add new CONFIG_AT91_LEGACYJens Scharsig
* add's the new temporary CONFIG_AT91_LEGACY to all board configs This will need for backward compatiblity, while change the SoC access to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated SoC is used. Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-08-18Update the mtd driver name in bootargs for at91-based boardsAlbin Tonnerre
The name of the atmel nand driver in the kernel changed from at91_nand to atmel_nand back in June 2008, but the at91-based boards config files still refer to at91_nand. This patch updates them with the new name Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
2009-07-22AT91: factor out ROUND() macroWolfgang Denk
A large number of boards (all AT91 based) duplicated the ROUND() macro in their board specific config files. Add the definition to include/common.h and clean up the board config files. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18NAND: Part 2: Fix warning Please define CONFIG_SYS_64BIT_VSPRINTF...Wolfgang Denk
Commit 8d2effea added a warning for configurations that use NAND without defining the (then necessary) CONFIG_SYS_64BIT_VSPRINTF but failed to fix the affected boards. This patch covers the non-PPC boards that were missed in the previous patch (commit 170c1972). Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-12at91: Introduction of at91sam9g45 SOC.Sedji Gaouaou
AT91sam9g45 series is an ARM 926ej-s SOC family clocked at 400/133MHz. It embeds USB high speed host and device, LCD, DDR2 RAM, and a full set of peripherals. The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. On the board you can find 2 USART, USB high speed, a 480*272 LG lcd, ethernet, gpio/joystick/buttons. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
