path: root/include/configs/at91sam9m10g45ek.h
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-09-14ARM: at91: Remove hardware.h included in configsWenyou Yang
As said in READRE.kconfig, include/configs/*.h will be removed after all options are switched to Kconfig. As the first step, remove the follow line from include/configs/*.h. #include <asm/hardware.h> Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-31env: Migrate CONFIG_ENV_IS_IN_FAT options to KconfigTom Rini
We rename the various FAT_ENV_xxx options to CONFIG_ENV_FAT_xxx so that they can be modified via Kconfig. Migrate all existing users to the new values. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-25Convert CONFIG_ENV_IS_IN_FAT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FAT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-09configs: at91sam9m10g45ek: Update to support DM/DTWenyou Yang
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Because the limitation of internal SRAM size, the SPL with driver model can't be supported, disable the SPL option. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_SYS_WHITE_ON_BLACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_WHITE_ON_BLACK Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y on various SoCs] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-18spl: Remove CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORSSemen Protsenko
This option isn't used for anything, so get rid of it. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2015-09-11ARM: atmel: boards: use default CONFIG_SYS_PBSIZEBo Shen
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-08-21arm: at91: mpddr: allow multiple DDR controllersErik van Luijk
The mpddr.c depends on ATMEL_BASE_MPDDRC for the base address to configure the controller. This cannot be used when there is more than one controller (i.e. AT91SAM9G45, AT91SAM9M10). Signed-off-by: Erik van Luijk <evanluijk@interact.nl> [remove 'new blank line at EOF'] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-04-01ARM: atmel: at91sam9m10g45ek: enable spl supportBo Shen
Supports boot up from NAND flash with software ECC eanbled. And supports boot up from SD/MMC card with FAT file system. As the boot from SD/MMC card with FAT file system, the BSS segment is too big to fit into SRAM, so, use the lds to put it into SDRAM. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2014-07-07env_fat: use get_device_and_partition() during env save and loadWu, Josh
Use get_device_and_partition() is better since: 1. It will call the device initialize function internally. So we can remove the mmc intialization code to save many lines. 2. It is used by fatls/fatload/fatwrite. So saveenv & load env should use it too. 3. It can parse the "D:P", "D", "D:", "D:auto" string to get correct device and partition information by run-time. Also we remove the FAT_ENV_DEVICE and FAT_ENV_PART. We use a string: FAT_ENV_DEVICE_AND_PART. For at91sam9m10g45ek, it is "0". That means use device 0 and if: a)device 0 has no partition table, use the whole device as a FAT file system. b)device 0 has partittion table, use the partition #1. Refer to the commit: 10a37fd7a4 for details of device & partition string. Signed-off-by: Josh Wu <josh.wu@atmel.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2014-05-27ARM: at91sam9m10g45ek: add mmc environment configuration supportWu, Josh
In this configuration the environment will save in file: uboot.env of mmc card. Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-05-27ARM: at91sam9m10g45ek: enable mci0 supportWu, Josh
Also we enable the mmc command in configuration file. As both CONFIG_CMD_MMC and CONFIG_CMD_USB use the CONFIG_DOS_PARTITION, so remove the redundant CONFIG_DOS_PARTITION definition. Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
