path: root/include/configs/at91sam9m10g45ek.h
2020-07-28Convert CONFIG_SYS_MMCSD_FS_BOOT_PARTITION to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_MMCSD_FS_BOOT_PARTITION Signed-off-by: Adam Ford <aford173@gmail.com>
2020-07-28Convert CONFIG_SPL_NAND_BASE et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SPL_NAND_BASE CONFIG_SPL_NAND_IDENT Signed-off-by: Adam Ford <aford173@gmail.com>
2020-07-28Convert CONFIG_SPL_NAND_DRIVERS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SPL_NAND_DRIVERS CONFIG_SPL_NAND_ECC CONFIG_SPL_NAND_SIMPLE Signed-off-by: Adam Ford <aford173@gmail.com>
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-21Convert CONFIG_NAND_ATMEL to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_ATMEL Signed-off-by: Adam Ford <aford173@gmail.com>
2018-05-23configs: at91: Adjust CONFIG_ENV_OFFSET to match sama5 addressNicolas Ferre
In order to have a single ENV_OFFSET to manage, use the same as the sama5 one. This address matches our NAND flash map available at: http://www.at91.com/linux4sam/bin/view/Linux4SAM/Sama5d3XplainedMainPage#NAND_Flash_demo_Memory_map Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com> [eugen.hristev@microchip.com: rework on latest version of u-boot] Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-09-14ARM: at91: Remove hardware.h included in configsWenyou Yang
As said in READRE.kconfig, include/configs/*.h will be removed after all options are switched to Kconfig. As the first step, remove the follow line from include/configs/*.h. #include <asm/hardware.h> Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-31env: Migrate CONFIG_ENV_IS_IN_FAT options to KconfigTom Rini
We rename the various FAT_ENV_xxx options to CONFIG_ENV_FAT_xxx so that they can be modified via Kconfig. Migrate all existing users to the new values. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-25Convert CONFIG_ENV_IS_IN_FAT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FAT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-09configs: at91sam9m10g45ek: Update to support DM/DTWenyou Yang
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Because the limitation of internal SRAM size, the SPL with driver model can't be supported, disable the SPL option. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_SYS_WHITE_ON_BLACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_WHITE_ON_BLACK Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y on various SoCs] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-18spl: Remove CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORSSemen Protsenko
This option isn't used for anything, so get rid of it. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
